Shift Linkages and Bolts
Old May 8, 2024 | 06:33 PM
aj simpson's Avatar
aj simpson
6th Gear
I have a 1970 F-100, and have recently dove in to the power steering mod. The column came out of a 1977 F-100 and it is a 3-spd column shift and I have found some linkages that would work. However, the way that the linkages connect are very different as one is threaded (my original ones) and the others have a slot for a special bolt to go through and connect to the transmission. I am currently on a hunt to find that special bolt and see if it will connect to my transmission. Thank You in advance!
Old May 8, 2024 | 11:34 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Special bolt that looks like # 7B415 by chance? C clip on one side and a nut on the the other?
Also check out the PDF attachment.
File Type: pdf
Old May 9, 2024 | 10:11 AM
aj simpson's Avatar
aj simpson
6th Gear
Yes and the retaining clip on the other side. i need all of that
Old May 9, 2024 | 01:49 PM
77&79F250's Avatar
77&79F250
I would think that the C clip can be from the auto parts store, maybe the funny bolt from the dealership?
Old May 10, 2024 | 08:38 AM
headloct's Avatar
headloct
These will work if it's what you need. Guy wants a lot of money but they are hard to find.
https://www.ebay.com/itm/16572368062...Z1VJXKRAD3GA7K
Or these...
https://www.mustangdepot.ca/drivelin...-transmissions
F2502011
Mar 25, 2025 10:15 AM
aj simpson
May 25, 2024 11:38 PM
sbilby123
15
Jan 12, 2024 03:43 PM
75f100hsv
May 1, 2019 11:24 AM
