Sponsored by: Real Truck
Front end/ 4wd question.
Old May 8, 2024 | 04:53 PM
Roa413's Avatar
Roa413
6th Gear
2006 F250 4wd, 6.0
I’ve recently got a pretty good vibration while driving at about 50mph. I got under the truck today and started checking u-joints.
I started at the rear moving towards the front and the u-joints on the driveshaft all appeared good .
moving to the front end however, I noticed I can spin the u-joints behind the driver side tire and while I was doing that the driveshaft joining into the transfer case was also spinning. The u-joints behind the passenger side front tire would not spin. I’m gonna guess this is NOT normal?
Old May 8, 2024 | 08:36 PM
apache84's Avatar
apache84
Not in 4wd/hubs unlocked, you should be able to spin either sider outer axle/U joint. You should also be able to spin the front DS.
Old May 9, 2024 | 09:44 AM
bajaphile's Avatar
bajaphile
Hopefully you ensured the passenger side hub was unlocked?
Old May 9, 2024 | 11:11 AM
Roa413's Avatar
Roa413
6th Gear
So last night I turned the hub selector and the. Turned it back to the original position and now it spins. I haven’t had the truck in 4wd for a few month.
Old May 9, 2024 | 11:42 AM
nydiver's Avatar
nydiver
Time to take the hubs out, clean them of old cakey grease, and reload them with a bit of grease for smooth operation. Clean and lightly grease the o-ring between your fingers, just a light coat of grease on it so hopefully it seals nice for a few more years, or replace it while you have it apart. Auto-hubs should be disassembled and greased yearly to ensure they don't act up, get sticky, or not operate at all due to vacuum leaks.
Old May 9, 2024 | 11:43 AM
Roa413's Avatar
Roa413
6th Gear
Thank you for all the info!
joey2fords
Feb 10, 2016 08:33 PM
donfordman
Jan 30, 2014 09:32 AM
Sullyf150
1997 - 2003 F150
Mar 28, 2008 08:28 PM
MustangGT221
Offroad & 4x4
Dec 28, 2004 07:15 AM
