U3012 error code?
Old May 8, 2024 | 09:47 AM
MeTo's Avatar
MeTo
U3012 error code?
This is my first solid check engine light with this truck; code U3012. I cleared it and will see how things go? Anyone else experience this code? Any info would be appreciated. Thanks and have a good day.
Old May 8, 2024 | 11:12 AM
Member No. 1's Avatar
Member No. 1
Rather Be Rid'n!
I haven't see this but a quick google search came up with this:
https://www.fordtremor.com/threads/c...ormance.15629/
Old May 8, 2024 | 11:36 AM
aquanaut20's Avatar
aquanaut20
U codes are related to the COMMs circuits, need a scope to diagnose..
Old May 8, 2024 | 11:37 AM
4wd6.7L's Avatar
4wd6.7L
https://www.ford-trucks.com/forums/1...l#post20832161
Old May 8, 2024 | 01:41 PM
MeTo's Avatar
MeTo
I just got back from running some errands, about 85 miles. No light. I read the TSB 23-2077 for this issue and the guy's comment about him taking his truck in to get the program update. He mentioned his truck rarely does the sick crow sound after and no more light. Mine does it a lot. Hopefully I can get it done under warranty also???
Thanks for the comments.
Old Jun 14, 2024 | 02:24 PM
Mk4160's Avatar
Mk4160
1st Gear
I had the same on my 2021 and the dealer told me the light keeps coming back it’s a software issue goes working on it . They checked my batteries and other things same code keeps getting kicked out . Even new pcm still happening currently waiting on a fix from ford
Old Jun 14, 2024 | 02:29 PM
aquanaut20's Avatar
aquanaut20
U codes are communication codes, you will need to get a scope on the comms lines and start proper diagnosis.. This is not a case of using a scanner to fix..
Old Jun 14, 2024 | 03:18 PM
MeTo's Avatar
MeTo
I deleted the code on May 6th and it's not been back. I'm still going to get the TSB update on the 20th. I have a friend who has done electronic/electrical work for Ford as a career. It will be a good opportunity to pick his brain and check if he would be willing to tweak a few things?
jwsrules
6.7L Power Stroke Diesel
Aug 7, 2024 08:09 AM
55F250
General Automotive Discussion
Sep 5, 2009 02:14 AM
That_Guy
Jan 2, 2008 06:45 PM
rmarion
1983 - 2012 Ranger & B-Series
Sep 19, 2004 07:51 PM
