starting problem
Old May 8, 2024 | 01:05 AM
philippe de marseille's Avatar
starting problem
Bonjour,
Le moteur de ma Ford F150 5.8 EFI de 1992 s’est arrêté subitement et je ne veux plus redémarrer.
La pompe à essence ne tourne plus alors qu’elle est neuve.
Quelqu’un a-t-il une idée pour m’aider ?
MERCI
Old May 8, 2024 | 09:00 AM
jas88's Avatar
jas88
Êtes-vous en train de dire que votre pompe à essence ne fonctionne plus du tout depuis que le camion a cessé de fonctionner?
Old May 12, 2024 | 11:59 AM
the vehicle suddenly stopped, no more ignition and the fuel pump no longer turns
Old May 13, 2024 | 09:12 AM
jas88's Avatar
jas88
Will it start on starting fluid?
Old May 13, 2024 | 10:12 AM
no spark at the spark plugs or at the coil. fuel pump not powered, fuse and relay ok
Old May 13, 2024 | 12:48 PM
jas88's Avatar
jas88
Sounds like either your ECU relay has failed or the ECU itself has.
Old May 13, 2024 | 01:10 PM
there is a way to check the ECU to be sure before ordering a new one
Old May 13, 2024 | 03:35 PM
jas88's Avatar
jas88
The only way I know is put in a known good one.
Old May 14, 2024 | 12:19 PM
Do you have any sites where I could find them?
Old May 14, 2024 | 04:13 PM
oldhard47's Avatar
oldhard47
I purchased a pcm ecm ecu for my 1994 f150 from FlagShip One. https://www.fs1inc.com/customer-service
Old May 14, 2024 | 06:23 PM
rla2005's Avatar
rla2005
Does the Check Engine Light (CEL) illuminate when cycling the key from Off to Run?
If yes, does it turn off when cranking the engine?
Old May 15, 2024 | 11:41 AM
The only lights that come on are:
abs
battery
Old May 15, 2024 | 12:22 PM
rla2005's Avatar
rla2005
Then you need to verify the power path to the computer (PCM) is good. Could be a bad fuse or bad contact on the ignition switch.
I would check Fuse U in the engine compartment fuse box first. Then Fuse I.
Old May 15, 2024 | 12:26 PM
fuse, diode and relay are ok
Old May 15, 2024 | 02:11 PM
rla2005's Avatar
rla2005
Is there power at Fuse U with the key in the Start and Run position?
Does the EEC relay energize when you cycle the key to the Run and Start position?
Is there power at Fuse I at all times?
