How to tell if truck has been "tuned"?
While it is possible to reburn the PCM it really isn't all that common. If it has been reburned it's usually to match some other upgrades like injectors. Even then it's typically a mild tune for streetability and diagnostics. A performance chip is the most common method of adding performance tuning and if it's ever been chipped then it will have a cut out in the PCM case removed and the board connection pins will have been cleaned.
The following users liked this post:
Outside of the tell tale physical evidence on the back of the PCM where you can see it’s been monkeyed with, not really, sometimes also in the dash there will be jury-rigged holes cut in the dash where switches or ***** were installed after the fact.
they can also be “flashed” with a single tune like mentioned above to where the PCM has different parameters but no outward signs it isn’t stock. You’d know by driving it. If it feels suspiciously peppy with a very sensitive throttle response and rolls coal even with a high flow air filter, that isn’t stock tuning.
The following 2 users liked this post by Brandonpdx:
Are you talking about stuff like the edge tuners? I was under the impression those didn't do much actual tuning. More along the lines of boost foolers and those kind of "upgrades". I don't have any real world experience with them only what I've picked up through reading.
If the PCM board has no physical evidence of having a chip connected to it (conformal coating will be scraped off of the edge connector) then at least that PCM (OEM or not) has not been "tuned" with a "chip". Most commercially-available flash programmers from Edge, Bullydog, SuperChips, et. al. leave behind a few miscellaneous bytes written to the VID block of the calibration after programming; even after returned to stock. The only way to find this is to actually read the calibration and look at it in a hex editing program. Scan tools cannot do this.
Thanks for the info,
This truck is very clean for the year, no holes in dash no additional gauges so no tell tale signs of being modified in any way. I'll have to look at the PCM if I get a chance.
All of that said what would be a good tune for this truck. it's a dually and I pull a 28' enclosed car trailer in the mountains sometimes.
Most likely a 25-40hp tow tune will be best for that application. That's assuming you have an EGT gauge installed first tho. Even a 40hp tune can get too hot on an ascent, yet be all the extra you really need.
All that assumes you have the entire truck @ 100% . The cooling fan engaging is more than enough to feel it when it robs 10-13% of the engine's HP output, so if your cooling system isn't up to snuff and you are heat soaked the entire trip the fan will stay on constantly, robbing you of useable power to the road (and about 2.5mpg)
https://cncfab.us/products/power-hun...dra-chip-hydra
The following 2 users liked this post by RacinJasonWV:
I have read that some tuned Fords will not connect to Forscan. It has to do with something that is changed by the tune that Forscan does not recognize as stock. I don't think a chip tune causes this problem. Check out the Forscan posts on this forum for more information. If you want more performance you will need a scan tool to monitor everything.
As I said truck is new to me and I have some basics to straighten out before I even think about changing the tune. Want to see how it pulls the way it is first and monitor the temperature. Cooling system looks to have been maintained and antifreeze is very clean looking. I'd say I'd need an EGT and a boost gauge also before changing the tune.
So much to think about.
EGT and boost gauge for sure, but I'd also suggest Fuel Pressure gauge. If something goes wrong cuts diagnosis in half.
If up pipes are OEM they need to be replaced with bellowed.
Hutch and Harpoon mods.
Oh my, I'm getting the vapors with all the options.
Basically we know nothing about the truck and we want you to be as happy as we are. Needs to fit your goals. When you can settle back for a long read try the Failure Prevention Thread, tons of info. Maybe kinda outdated by now but serves as a great primer on these trucks.
The following 3 users liked this post by aawlberninf350:
