Wire harness wrap/tape
Old May 5, 2024 | 09:02 AM
Khardee's Avatar
Khardee
4wd High
Does anyone know where to source the thin orange tape used to wrap the wire harness leading to the BCM?
Old May 5, 2024 | 10:01 AM
Rich1961's Avatar
Rich1961
Old May 5, 2024 | 12:15 PM
Khardee's Avatar
Khardee
4wd High
No, it is a semi-transparent, relatively thin, orange plastic tape. I’ll take a picture and post it shortly.
Old May 5, 2024 | 03:46 PM
Khardee's Avatar
Khardee
4wd High
Old May 5, 2024 | 03:55 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
Any reason standard electrical tape won’t work?
Old May 5, 2024 | 03:59 PM
Khardee's Avatar
Khardee
4wd High
living in south Mississippi, the inside of a vehicle gets super hot. Just in case I have to open it up again, I would like to use something similar to the OEM tape as it doesn’t get gummy when exposed to high heat.
Old May 5, 2024 | 04:19 PM
Bruce M.'s Avatar
Bruce M.
You want to use what’s called “friction tape “
https://a.co/d/5piUl6A
Old May 5, 2024 | 04:22 PM
Don Ridley's Avatar
Don Ridley
Use 3M Super 33 or Super 88 electrical tape. It does not get gummy and is very stretchy. Best electrical tape made. I have never found the thin, lightly gummed tapes used to wrap wiring harnesses.
Old May 5, 2024 | 07:45 PM
TB250's Avatar
TB250
The black fuzzy tape above in the upper third of your photo and used on most of the interior harnesses is Tesa Tape. amazon.com/Tesa-Fleece-Interior-Harness-Mercedes/dp/B00NN6B9R6
Old May 5, 2024 | 08:26 PM
Rwhjr's Avatar
Rwhjr
https://www.opgi.com/ignition-electr...l-wr16133.html
Old May 8, 2024 | 08:07 AM
Khardee's Avatar
Khardee
4wd High
I am looking for the semi-transparent orange wrap tape
Old May 9, 2024 | 06:47 AM
Squirrel13's Avatar
Squirrel13
Tessa makes a high temp version of the cloth tape. My guess is that it wouldn’t get gummy
Old May 9, 2024 | 07:20 AM
Khardee's Avatar
Khardee
4wd High
that looks very similar! Thanks!
Old May 9, 2024 | 11:15 AM
jchristian11's Avatar
jchristian11
https://www.waytekwire.com/product/s...caAvUXEALw_wcB
Chips2000
Apr 12, 2018 09:09 PM
