LED blinker module... FYI
Old May 5, 2024 | 08:29 AM
Meridian_Mike's Avatar
Meridian_Mike
Just so any concerned truck owner... WHO HAS TRIED TO CONVERT TO LED...... will know.
I bought my LED conversion module about a year or so ago. When I plugged it in yesterday... my blinkers would not work. SO... I plugged my old incandescent OEM blinker module back in and the blinkers worked all goofy. (Like it should with LED bulbs in place)
SO... I figured I had a bad ground. NOPE... no matter what I did INCLUDING running a jumper wire straight from the battery.... the new LED module would not work.
Then, I figured I must have a bad LED module.
I went to a parts web site to get a new LED module and I see the new modules come with a jumper to reverse the blades on the module. THAT MEANS... the module has to be plugged into the socket one way ONLY in order to work. If the module doesn't work, just plug on the jumper and plug in the module opposite what it does normally.
I made myself a set of jumpers to reverse the blades on the module.......
I grounded the module and plugged it in with the blades reversed..... AND NOW..... it works perfectly. YIPPEE!!
If you have an older module you might have a problem like this. BUT.... the new modules come with a way to reverse the module plugs.....
This is just a FYI for those with the older LED modules that don't seem to work.
I hope this helps someone.
Old May 5, 2024 | 08:56 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Thanks Mike, great info right there for sure.
RAP62
Apr 19, 2023 01:16 PM
Dale Massey
Aftermarket Products
Jan 31, 2019 10:14 PM
txazguy
6.7L Power Stroke Diesel
Mar 24, 2017 04:47 AM
04F-250mark
Mar 7, 2012 11:32 AM
homedepothauler
Nov 12, 2002 09:21 AM
