Injectors
Old May 4, 2024 | 01:45 PM
57for's Avatar
57for
Injectors
Good afternoon I have a crank no start scenario.
It’s a 93 ford f150 300 I.
New fuel tank new pump coil plugs cap rotor.
It has plenty of spark,58 lbs fuel pressure.When cranking noid lights pulse and I can hear injectors ticking.If I pull spark plug it’s dry.
What would cause this not to start other then plugged injectors.
Old May 5, 2024 | 06:16 AM
FuzzFace2's Avatar
FuzzFace2
If you spray starting fluid dose it do anything?
What was done before this happened?
Where you checking for spark at coil wire to block or plug wire to block?
Are you checking for power at the injectors or ?
What codes dose the computer show?
Dave ----
Old May 5, 2024 | 07:01 AM
57for's Avatar
57for
It will run all day on either.
i was given this truck it sat for a year or so.The fuel was bad in it that’s probably what trashed both front and rear fuel pumps.
I check for spark at each plug wire with spark plug tester with ground to battery.
injectors are getting 12 volts.
codes were 332 543 542.I imagine the latter 2 are from the fuel pumps being trashed.The egr I thought was from it not running.
When I cover the throttle body with my hand it does a better job of wanting to start then without covering it.
could it be a maf sensor or throttle sensor.
It’s hard to believe all injectors are plugged.When cranking over I can hear then clicking with stethoscope.
Old May 5, 2024 | 12:43 PM
57for's Avatar
57for
It will fire right up
truck was given to me man can’t see anymore.Codes are 332 543 and 542 latter 2 are probably trashed fuel pumps 332 egr I thought that it was not running so it was showing that.
check flow power at injectors 12volts and flash when cranking.
when cranking I can here all injectors clicking.
Old May 5, 2024 | 01:31 PM
57for's Avatar
57for
I just did a smoke test for vacant I had a littte coming out of my throttle body linkage and a lot out of egr valve and also charcoal canister. Would these cause a lean no start.
Old May 7, 2024 | 02:50 PM
FuzzFace2's Avatar
FuzzFace2
Between all 3 it could be and more so for the EGR as that could be pretty big.
Canister you could plug off, same for the EGR.
Pull the valve and using a pop can cut a piece that will cover the opening and bolt the valve back in place.
On the TB sorry to say it will need to be replaced. Are you sure it is from the TB shaft & body and not a gasket between the TB and manifold?
Thing is you say it will run on starting fluid but if you stop spraying the motor also stops running right?
If so I would think once started with fluid it would stay running with all them leaks?
Dave ----
Old May 11, 2024 | 02:39 PM
57for's Avatar
57for
Dave I put a map sensor in and also a manifold sensor in the original ones were pretty nasty looking.
Now as far as plugs were 1 of them was wet one was a little wet rest were dry,after I tried to start it.One Plug was wet another 2 cylinders down was a little wet rest were dry.
Would you go ahead and pull injectors it it was yours.
Compression check was 160 175 175165170 165.
Old Jun 29, 2024 | 12:53 PM
Anton deTeton's Avatar
Anton deTeton
@rla2005 No, the the ICM is not mounted on the fender. It is distributor mounted, grey, without the 3 vertical spade connectors that go into the dist body. It plugs into a 6 wire harness, next to the PIP harness. The thing ran fine, until it didn't. Looking at the Hall effect component seems logical, making sure it's not gunked up and I want to make sure the plug is clean and tight. And, as stated, this serves as a crank reference sensor, yes? If it has failed it makes sense the injectors don't know when to fire.
FcknClueless
Apr 3, 2024 07:00 PM
96150
May 12, 2023 09:00 AM
Ray6797
2004 - 2008 F150
Feb 26, 2022 04:47 PM
Snoshow
Oct 16, 2016 02:47 PM
stoopideric
May 22, 2016 06:05 PM
