1978 - 1996 Big Bronco
Bucking bronco
Old May 3, 2024 | 09:40 PM
shelbyleader's Avatar
shelbyleader
1st Gear
Bucking bronco
I have a 1986 bronco 302, ( new truck to me) . When i accelerate it starts bucking ( missing) if i push it passed 2000rpm when driving it gets worse. Can usually get about 45mph with only occasionally miss anything passed that gets worse. Last night at 45mph i put air on and it got worse, turned air off and ran headlights and it got worse again. I have changed coil, dist, cap rotor plugs,wires, ignition, fuel filter. Idles fine, revs fine, . Tac needle drops everytime it bucks.alt is charging at 14.4 volts. Do those engines have serpentine belts or v belts, mine has v belts, and 2 belts off alt. I thought is voltage regulator bad inside alt? Help? Thanks
Old May 4, 2024 | 10:35 AM
manicmechanic007's Avatar
manicmechanic007
Your TFI module and stator may be failing or the ignition coil
Use a spark tester on the coil wire and watch the spark
Use another spark tester on a plug wire just in case
See if the spark goes away when the miss happens
You can use two coil wires and run the tester outside the hood and drive it if necessary for testing
Use both types, The type where the spark jumps the gap and the ones with the light
Watch the one while you listen for the other
Old May 4, 2024 | 07:47 PM
Beechkid's Avatar
Beechkid
I would fuel pump to the above list as well.......
boss_man2171
Jul 26, 2021 07:40 AM
Gordesky Mco
Aug 10, 2014 04:32 PM
jb50F1
26
Jul 5, 2010 07:37 PM
lawnboy58
Bronco II
Jun 9, 2007 11:42 PM
oldgost
Bronco II
Apr 13, 2004 01:40 PM
