C6 transmission vacuum or gears?
Hey guys. To give a long story short I bought a 1989 f250 with a 7.3L idi and a c6 transmission. It's been going great for the couple days I had it. But today after I did a fuel filter change this morning it's been shifting terrible. It will hold onto 1st gear up until 25 mph and 3500 rpm. I tried adjusting the vrv and I turned the modulator counter clock wise 1/2. In both scenarios I would adjust, then test over and over but the results felt the same no matter what. Yes I checked vacuum lines. Is this a sign of the vrv going bad or the modulator? Or is the transmission near the end of it's life. I need to pick some brains here before i go crazy. Thanks 😊
Received 3,227 Likes
on
The following users liked this post:
I just had my VRV rebuilt by one of our members, @genscripter He did a great job. Here's his website, with instructions on testing a VRV.
https://www.nickpisca.com/diesel/
Be careful test driving your truck to set the vacuum modulator and VRV. If you can't easily dial it in you can torch the transmission.
Ultimately, you need at least 13inhg to be the BARE minimum before you'll notice shifting issues thru the VRV.
RGTB
12-24-2021 08:09 AM
william16339
10-21-2016 10:17 AM
Piper106
02-05-2012 12:30 PM
kermit
06-17-2005 03:26 PM
