Transmission Revving, Terrible shifting, Sensor problem?
Old May 3, 2024 | 11:36 AM
AlwaysUpsideDown's Avatar
AlwaysUpsideDown
2nd Gear
Greetings!
​​​​​​ First time posting here.
I have a 1992 F-150 with the 300 I-6
The truck started having hesitation shifting at speed, would rev, then drop, rev then drop, over and over, and then finally shift but the rpms would be pitifully slow. Seems worse under load or on hills.
Computer showed a bad TPS, so I changed it with a brand new motorcraft TPS, same issue is still occuring. Same code still showing.
​​​Also tested fuel pressure, seems fine to me.
Truck is currently not safely driveable, worried it's going to tear itself up. I am baffled at this problem, have not been able to figure out the cause yet.
Wondering if anyone out there with similar experience?
Old May 3, 2024 | 12:42 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
There is no code that says the TPS needs to be replaced. Many (most?) of the TPS codes are due to a damaged wire between the TPS and the computer. Diagnose what's wrong with the wiring.
Old May 3, 2024 | 01:13 PM
AlwaysUpsideDown
2nd Gear
I will try to probe the wiring at the computer for the correct voltage. Thank you for the lead.
Old May 3, 2024 | 01:59 PM
Mark Kovalsky
That's not how you do it.
You need to check the wiring for continuity from one end to the other. Also, check each wire to the TPS for short to ground and short to power.
Papaswoodworking
1997 - 2003 F150
Feb 1, 2013 10:55 AM
Silentst2000
22
Jul 5, 2005 07:33 PM
richdb
General Automotive Discussion
Apr 6, 2005 08:39 PM
Jeff2K1Z
Dec 10, 2003 09:12 AM
