Bench testing new ICVR
Old May 2, 2024 | 08:58 PM
Centennial F100's Avatar
Centennial F100
I am a newbie to auto electrics. I am replacing my instrument cluster lights with LEDs and figured I may as well replace the instrument voltage regulator at the same time. I have a new Dennis Carpenter solid state ICVR. I read on the forum that it is worth bench testing it before installing it, since some of the "made in China" ones don't work correctly out of the box. I plan to use a 12 volt truck battery and hook it up as per the sketch, hoping for a solid 5V reading. Is this the correct way to test it? Comments appreciated.
Old May 3, 2024 | 11:55 AM
smoky_diesel's Avatar
smoky_diesel
Yes that is the correct method.
It will not out put a steady 5V. It is a thermal switching type regulator, and will bounce around from 3-7 v to average 5 v.
Old May 3, 2024 | 12:57 PM
Centennial F100
Thank you. I thought it looked like the old type with the bi-metal strip, but it was advertised as solid state, so I will look for the voltage swing. I guess I could bend a tab or two back and have a peek inside, who knows these days what one will find. I will use a test light as well to detect the pulses, since my tester is digital.
Old May 3, 2024 | 01:29 PM
Centennial F100
Got me curious so I opened it up. Solid state apparently. The black is a poured material, epoxy maybe.
Old May 4, 2024 | 08:00 AM
1TonBasecamp's Avatar
1TonBasecamp
Yes, the solid-state ones look just like the originals on the outside. Or fairly close to them.
Yes a modern IC type will put out a steady voltage.
And yes, it’s a great idea to test them!
Because yes, many of them are crap.
The ones we sell for Early Broncos come from several sources, but also have a little adjuster on them. Luckily…
So when they arrive and we test them and they put out too little or too much voltage, we can adjust them to put out a steady 5v.
Doesn’t look like yours has an adjustment on it, so hopefully they work right out of the box.
Did you get a chance to test it yet?
Old May 4, 2024 | 12:03 PM
Centennial F100
Paul's question: "Did you get a chance to test it yet?"
Yes, 4.96 Volts which is close enough to use I guess, since there is no adjustment. I will test the one I that's in there now to compare.
Is there a resistor encased in the black filler, or is the black filler a resistive material? I suspect the former, but as I said this is all new stuff to me.
Old May 4, 2024 | 09:11 PM
1TonBasecamp
I would suspect that it’s just simple potting material and that the resistor is inside. Luckily this is very low current flow, because resistors can build a lot of heat. And anybody with a Ford Dura, spark, ignition, module meltdown, can certainly see what happens to potting material when it overheats! :-)
Centennial F100
Dec 15, 2023 11:44 PM
captainpease
May 18, 2023 12:43 PM
hdman90
Mar 31, 2022 12:17 PM
Blucky
Jul 13, 2021 05:06 PM
rmodel65
Sep 18, 2014 07:55 PM
