Sponsored by: Real Truck
E-Brake delete
Old May 2, 2024 | 08:11 PM
jdub1177's Avatar
jdub1177
E-Brake delete
Quick question - has anyone deleted the e-brakes on their Sterling 10.5? I’m swapping these axles into a 75 highboy and going with a NP205 e-brake instead. Just curious if there is any reason to leave them hanging on the axle?
Thank you in advance
Old May 3, 2024 | 02:24 AM
Jon Does's Avatar
Jon Does
Trailering
Actually it’s not an E Brake, It’s a parking brake.
Betcha most of the older SD trucks have inoperative parking brakes simply because the brake backing plates commonly rust out… just like the ones on my 05 F250 2wd.
Old May 3, 2024 | 06:23 AM
jdub1177's Avatar
jdub1177
e-brake / parking brake = same thing. Any insight to my question? Can I remove the associated component on the ends?
Old May 3, 2024 | 07:46 AM
apache84's Avatar
apache84
I cant see any reason to leave them hanging around,however its been a while since I dig around on the rear diff. Im jealous, my first 4x4 truck was a 75 F250, Np435 trans, 205 case, 360. Should never sold her.
Old May 3, 2024 | 08:01 AM
jdub1177's Avatar
jdub1177
I probably should be more specific. It’s the drum assembly behind the calipers I’m specifically wanting to delete. I’ve eliminated all lines associated with the e-brake / parking brake / potato (whatever you want to call it)
Old May 4, 2024 | 05:53 PM
Tpayne621's Avatar
Tpayne621
Yea it won't hurt anything to take it all off.
wyandotteman
Apr 19, 2022 05:59 PM
sandymane
Jul 19, 2019 06:56 PM
ZachManXLT
1997 - 2003 F150
May 1, 2016 02:17 PM
Dans2Fords
Feb 27, 2012 11:08 AM
