I am trying to order parts for my platinum 2017 f350 diesel. When i call ford they wont give me part numbers. I understand their reasoning because they know i will just order elsewhere and their right....their prices are insane. Id like to use oemfordparts.com or the like, but i need the part numbers. Is there anyone here that has access to oem ford part numbers if provide the VIN : HEB66803
I need:
right tie rod
left tie rod
pass side upper and lower ball joint
wheel hub bearing assembly both sides
track bar
thanks. I’ve done that but multiple parts come up each time. It’s very odd.
I just tried using my VIN and keywords like "tie rod" and "ball joint", it gave me results for those parts on the first page of the results. Also, once you find one part it will typically have "related parts" under it. Sure it loads multiple pages with unrelated parts that might contain a word from the keyword, just ignore the results you aren't interested in.
I need:
right tie rod
left tie rod
track bar
Thanks in advance !!
Maybe I'm crazy but that VIN is not complete so it's useless for me trying to help you. Is your truck 4x4? SRW or DRW? Any special suspension packages?
Go to PMF Suspension (PMF Suspension For 2017 F-350) and order the actual steering components from them. You'll get much better quality parts than OEM. You won't find the "wheel hub bearing assembly" there though.
According to RockAuto.com:
The Motorcraft rear hub for SRW is HUB343 (HC3Z1109D).
The Motorcraft front hub for 4x4 SRW is HUB344 (HC3Z1104C).
The Motorcraft front hub for DRW is HUB345 (HC3Z1104D).
Finally, the Motorcraft front hub for SRW 2WD with HD front suspension is HUB346 (HC3Z1104E).
