Running too rich?
Old May 2, 2024 | 01:23 PM
Steve1920's Avatar
Steve1920
Running too rich?
Guy's
I havn't used it much as of late, but last fall while putting it away and again upon start up this year, my '41 ton and half with an eight and a Ford carburetor just about makes your eyes water from the exhaust fumes. It doesn't run terrible, but the odor tells you something is a miss.
What should I look at first upon teardown? Is there a "most likely, somewhat likely, not likely" list of components that would cause excessive gas into the engine? Bad float, bad seat, power valve, accelerator pump, other? Just trying to come up with a game plan and possibly order some parts ahead time so they are at the ready.
Thanks in advance on any help or information you can give me on this.
Steve
Old May 2, 2024 | 02:00 PM
85e150's Avatar
85e150
What do the plugs look like?
Old May 2, 2024 | 08:13 PM
Steve1920's Avatar
Steve1920
I'll take a look at them, but they were not bad the last time I looked at them. That is why I was leaning towards some sort of carburetor component failure. But if by some chance a plug cleaning or replacement improves things, I'll be very happy!
Old May 4, 2024 | 11:30 AM
Rust Wrangler's Avatar
Rust Wrangler
You pretty much listed the likely possibilities. Bad power valve is the first thing that comes to mind, that and a faulty choke.
Good luck!
Old May 4, 2024 | 05:34 PM
FuzzFace2's Avatar
FuzzFace2
What type of gas is in the tank and how old is it?
Todays gas dose not last long and could also be a cause.
I also take it you dont drive it much?
That also dose not help matters much as it cant heat up enough to burn the condensate out of the crank case or any un-burnt fuel in the oil.
And what about the heat to burn the plugs clean?
Just my .02
Dave ----
B_line66
Aug 7, 2015 07:21 PM
OLDFORDPEOPLE
Dec 9, 2013 08:59 AM
guthrie&co
Garage & Workshop
Oct 21, 2010 07:36 PM
Weaselpolooza
1983 - 2012 Ranger & B-Series
Jan 13, 2007 05:31 PM
juggerknot
Apr 2, 2005 04:10 PM
