Tire/Wheel Change
Tire/Wheel Change
Hi all,
I am thinking about changing out the wheels and tires on my 2002 F250. Currently has a 4” lift with 35’s on Fuel 17” Wheels (see photos).
I want to move toward something more stock. I dont want/need the off road tires. I found a set up I like with the 05-08 stock wheels. My question is for the current set up I have, can I just swap any 16,17,18” stock wheels with stock tires onto my current set up?
Current setup
Current setup
this is an idea that I like but with less “knobby” tires
Current setup
Current setup
You CAN put wheels from any later offering on your pickup as long as it's a single rear wheel vehicle. However, the backspacing increased by almost 2 inches starting in the 2005 model year so you will need wheel spacers to keep the tires from rubbing the leaf springs on sharp turns or just get used to it. It will look goofy from the front and back too.....think railroad pickup.
yeah i rarely cheap out on much but definitely not on wheels, brakes, suspension/steering lol. These are 16x7. Is that the factory spec for 99-04? I assume something like this could bolt right on? Sorry I am illiterate with wheel jargon.
thank you! Makes sense. Also- running 35’s … what modifications if any do you recommend for suspension and gearing? I am thinking about just moving back towards something like 33’s. I basically want the truck to last me awhile and not blow up my suspension components, transmission, etc.
Yep. 4x4 Excursions never got the wider wheel mounting surface width change, bigger brales, or coil spring front suspension like the F250/350 in 2005.
In my opinion (for what it's worth), the 18" wheels offered in 03 and 04 are the best looking wheels. They were offered in the Harley Edition (with corresponding logo) and the plain version without the fancy center caps or logo.
This man sent back "They're really rare, so I'm not taking any less than $3000."
I told him to have a good day.
Been on the lookout for a set of these (the plain, lariat version) for years. Finally saw a set on Marketplace that was close by, but the guy had no price listed. Shot him a message asking "How much do you want?"
hahaha thats insane. Thanks all. i think I may run those I posted above. I want to stay away from running spacers. Just want a nice stock looking wheel that wont look too puny under my 4” lift.
Brushed factory wheels...
04 King Ranch wheels with 33" tires...
04 Lariat wheels with 35" tires...
