Chattering noise at idle?? (Please help!)
Old Apr 29, 2024 | 08:05 PM
miami7.3's Avatar
miami7.3
2nd Gear
Hello!
1997 F250 HD 254k
4" DP/exhaust
S&B Intake
Jelibuilt Hydra
I cannot figure out this noise for the life of me. I just took took the truck on a 1000 miles trip towing a small boat, and when I got back, the lift pump was leaking a solid amount of fuel.. I don't like to take my truck to shops, but I needed it that next week and dont have time/space to diagnose at the moment. They changed the lift pump and the leak stopped. I installed the tuner after this, had some fun in the DD tune (no hard shifts/launches.etc) and towed a 8k trailer a relatively short distance the following week.
Truck started making this noise at idle.. You can hear it very clearly in the cab, so I messed with the alignment on the DP, but it's still making the noise. It's very clear from the passenger side of the truck and underneath.. Sounds like it's coming from TC/flywheel??
VIDEO HERE
Old Apr 30, 2024 | 01:14 PM
knottyrope's Avatar
knottyrope
loose TC bolt or broken / loose flywheel and the flywheel moves too much IMO
Old Apr 30, 2024 | 04:30 PM
miami7.3's Avatar
miami7.3
2nd Gear
That's what I thought as well.. All TC bolts are tight. Interstingly, while I was turning the FL over with the TC bolts, I was able to hear air escaping from where seemed to be my oil pan gasket... Fun.
Paul Mattick
Nov 28, 2021 11:09 AM
nicholas116
2004 - 2008 F150
Dec 28, 2016 07:15 PM
Sparkplugless
15
Jul 15, 2015 10:08 AM
BigBody
Aug 10, 2011 07:38 PM
ncarr275
30
Apr 16, 2011 04:32 AM
