2017+ Super Duty The 2017+ Ford F250, F350, F450 and F550 Super Duty Pickup and Chassis Cab
Rotella T6 from Amazon
Old 04-29-2024, 10:14 AM
johndeerefarmer's Avatar
johndeerefarmer
johndeerefarmer is offline
In the past I have bought 1 gal and 5 gallon jugs of Rotella T6 from Amazon. This time I bought two 2.5 gallon jugs. They came in cardboard boxes with no markings of any kind. The jugs were in plastic bags. On both jugs the seal was partially open- crinkled up seal. Since one was spilled Amazon is sending a replacement. I want to see if the seal looks like it was messed with as well.
Wondering if this is real Rotella? It came from Amazon not a third party
Old 04-29-2024, 10:22 AM
OBS460's Avatar
OBS460
OBS460 is offline
Received 1,542 Likes on 995 Posts
I always just looked on Homedepot.com or Walmart to find T6 in 2.5 gallon jugs. Amazon has A LOT of reviews from people buying oil that they show up leaking.
Old 04-29-2024, 10:48 AM
acdii's Avatar
acdii
acdii is offline
Received 2,072 Likes on 1,408 Posts
This This
is the only T6 I will buy from Amazon.
Old 04-29-2024, 11:09 AM
4wd6.7L's Avatar
4wd6.7L
4wd6.7L is online now
Received 2,112 Likes on 1,590 Posts
My only experience with the 2.5 gallon size was from Tractor supply, in store. I had to pick through a few because some were leaking. At the time the 2.5g size used a seal, the seal was loose or lifted a little on the ones leaking in store. Never experienced that with the gallon size from anywhere I've purchased, whether online or in store, but they also have a different cap and seal arrangement.
Old 04-29-2024, 11:13 AM
99powerstrokedF250's Avatar
99powerstrokedF250
99powerstrokedF250 is offline
Biggest I've ever purchased was the '5 quart' jugs, which would be a gallon and a quarter. Some places carry the gallons, others the gallon and a quarter. Much bigger than that, though, and they get to be tough to manhandle and the chance for spillage goes up.
Old 04-29-2024, 11:57 AM
Ltngdrvr's Avatar
Ltngdrvr
Ltngdrvr is online now
Received 3,418 Likes on 1,805 Posts
Man, you'll have to show us that one.
I've never seen shell rotella in a 5qt jug.
To the OP, I know amazon sells a lot of stuff that they buy in bulk from china/india and package themselves for resale in unmarked packaging, but have never seen real rotella oil come in anything but actual shell labeled jugs and boxes, I sure would be wary of that oil they sent you.
Old 04-29-2024, 12:00 PM
4wd6.7L's Avatar
4wd6.7L
They would come in unmarked boxes if they aren't normally packaged and sold in that quantity from Shell. Like if I were to order two, 1 gallon jugs I wouldn't expect it to come in a Rotella marked box.
Old 04-29-2024, 12:06 PM
Ltngdrvr's Avatar
Ltngdrvr
But, shell does sell 2.5 gallon jugs, so something is off.
Old 04-29-2024, 12:10 PM
chadstickpoindexter's Avatar
chadstickpoindexter
chadstickpoindexter is online now
Received 2,435 Likes on 1,468 Posts
This is why I try to order things from anywhere but Amazon… and if I want something of value and I want to know it’s authentic, I won’t order it from Amazon. There are exceptions, like if the item I am ordering is listed to ship from the actual company.
But if it isn’t in an actual Rotella T6 jug, I wouldn’t use it. Send it back.
Old 04-29-2024, 12:15 PM
stryder's Avatar
stryder
stryder is online now
Originally Posted by acdii
This is the only T6 I will buy from Amazon.
That's all I order anymore as well. Comes in original Rotella box. Never had an issue with leaks. The 2.5 gallon jugs I've bought locally definitely are not sealed the best.
Old 04-29-2024, 12:18 PM
johndeerefarmer
Thanks, I guess they have issues with their seals on the 2.5 jugs. All of my 1 gallon jugs have the lid like a water bottle where you twist it to break the ring at the bottom
Old 04-29-2024, 12:29 PM
SARDiverDan's Avatar
SARDiverDan
SARDiverDan is online now
I tried Amazon for T6 once. The order never showed up. I go to Walmart or a local Auto Zone when they have a deal. The Tractor Supply stores out here never seem to have any.
Old 04-29-2024, 12:33 PM
4wd6.7L's Avatar
4wd6.7L
Yes, but maybe not in a two jug quantity. Maybe I'm not understanding what the issue is.
Old 04-29-2024, 12:40 PM
Phillbo's Avatar
Phillbo
Phillbo is offline
I would not put it in my truck. Someone may have sucked out all the T6 and pumped in a lower grade oil just to make .16cents more profit........
Old 04-29-2024, 02:47 PM
stryder's Avatar
stryder
If you buy the 3 one gallon case that Acdii linked above, it comes in a sealed box from Rotella. It may ship from an Amazon warehouse, but it's factory sealed. The gallon jugs also have the tinfoil type seal under the sealed cap. So would be pretty difficult to pull off a switch without noticing.
Quick Reply: Rotella T6 from Amazon
