I have a 6.2l 2018 super-duty with around 50k miles. This weekend I was towing a camper, suddenly my air bag light would come on and make a click sound when braking. After dropping the trailer it continued but now also says “trailer battery not charging see manual,” while there is no trailer in addition to the air bag light coming on and off. Also, my directional will randomly speed up as they do when a bulb is out at the same time at a light. Googled all over and can’t find anyone with the similar problem. Anyone have any thoughts?
I own a 2017 6.2 and from reading the forums in the past, when you get electrical glitches, the first thing you should check is the battery(ies). If they are not good, it can cause this type of thing. And from reading previously, really check them at a shop that knows batteries.
When you have completely isolated systems acting up(airbag idiot light, signal lights, trailer batt tender), check your grounding.
Take a meter lead from the engine block to the frame with ignition off and make sure you get zero ohms as well as frame to batt negative and cab to frame etc. (DISCONNECT NEG LEAD OF BATT SO YOU DON'T BLOW YOUR METER FUSE!!!)
Repeat same test this time in volt scale and with ignition on, make sure there is no potential difference on each component.
It's also easy to check alternator charging voltage, make sure it's around 14.5 volts.
Also check the infamous plug up near the spare tire for water intrusion/corrosion. Personal experience and many posts here over the years show that to cause all kinds of weirdness.
Battery, alternator and ground all tested good. Nothing that I can see for moisture around the plug near the spare. Today I have more things starting to add to the mix. One being “check park system light” on dash going on and off with others and the hvac system staying on when in park, ignition off and key removed. Sounds like a trip to ford is in store.
My cousin just went through this on his 2020. The auto parts store "tested" his batteries and said they were good. The random issues continued. He finally took it to a dealership and they did a proper load test on the batteries and found that one of them was failing the load test. Two new batteries and all his issues went away.
You have an issue with an intermittent short or poor ground. I don't think it's your ignition switch. The ignition switch can be easily checked with a scanner and live data, so it's easy for any mechanic worth their salt to do.
The HVAC module not sleeping is a key issue. Is it repeatable? Do you have remote start?
I'd do a visual inspection of the under hood wire looms.
Don't touch anything! This problem screams intermittent caused by insulation failure. Perhaps you can see the harness rubbing against the block, frame or a bolt.
If you go in there and start messing with wires, it may go away for a while.
You could try to get it to repeat and while the HVAC is running with key out, gently and systematically move specific parts of the harness, until the system shuts off.
Hopefully the dealer has a GOOD diagnostic technician. I would refuse any parts replacement unless it has been proven to be the cause of failure.
