Big block/Small block difference
Old Nov 28, 2003 | 06:45 PM
Redneck-Cowboy's Avatar
Redneck-Cowboy
millertime300: I've been lookin for headers for my 300 in an carbed 86 F-150 4x4 w/ a 4 spd. Those hedmans are only for 2wd, do see any reason why they wouldn't work on my 4x4? There is really nothing to get in the way. I also wanted to know if the offy was worth it and did you need the $99 adapter kit? I suppose you're using a edelbrock 500cfm, if so how does it handle it, b/c I really don't want that over priced Holley they want you to use.
Redneck-Cowboy
Old Nov 28, 2003 | 10:35 PM
swann79's Avatar
swann79
Ford considers the 351C, 351M and 400M to be "mid blocks"
Old Nov 29, 2003 | 11:53 PM
Jakes69's Avatar
Jakes69
Ford engine parts interchange book refers "small block" engines as the 221,260,289,302,351w,351c,351m,400m. "Big block"All F.E. engines 332,352,360,390,406,410,427,428. And the 385 series 429/460.
Old Nov 30, 2003 | 10:29 AM
78fordman's Avatar
78fordman
What did the 385 come in?
Old Dec 1, 2003 | 02:12 AM
Jakes69's Avatar
Jakes69
The 385 series or 429/460 were originally for large passenger cars, fuel consumption forced them into trucks.
Old Dec 1, 2003 | 02:17 PM
millertime300's Avatar
millertime300
Jakes69
Old Dec 1, 2003 | 02:23 PM
millertime300
Sorry for the double post.
Jakes69 I was refering to the fact that the M series motors use the big block bolt pattern. I wonder why Ford made so many motors anyway.
Redneck-Cowboy
I got my hedman header from summit I think, it might have been jegs. I didn't have to buy an adapter. I did make a very very very simple throttle cable mount that I am sure you could make. My header does look like it would work on a 4X4. Look around the forums. Somone in here has a bronco with a 309 (300 with .30 or so over) He has a header, but it might be a clifford.
It says in his signature.
Yes my carb is a 500 cfm edelbrock. If I remember I had to get on size larger jet for the primaries. They are supper easy to work with. You work regret it. If edelbrock/carter made a smaller carb I would have bought it. But I will never again buy a Holley now that I have had an edelbrock/carter.
redneckcowboy.jr
36
Feb 7, 2013 06:34 AM
Redneck-Cowboy
Jan 17, 2012 10:05 PM
Redneck-Cowboy
Jan 24, 2006 09:59 AM
Redneck-Cowboy
Jan 18, 2006 11:46 AM
Redneck-Cowboy
40
May 20, 2004 07:48 PM
