Detroit-Eaton True Trac TRACKS
The following users liked this post:
Originally Posted by John in OkieLand
for those who are still wondering, which locker diff should I buy?
After a LOT of forum reading, I decided to go with the Detroit True Trac.
Why, because under normal conditions, you don't even know it is there, I have driven this truck over 6,000 miles since it was installed, and finally, I got to see it work.
Up in Cleveland, Utah where I am now, the farm is up on a hill, and the soil is a mix of cliche and clay. I knew when I went to town, that coming back was going to be trouble.
It started raining last night about 8pm and kept it up all night long, not heavy, just a continuous light down pour.... not enough to make ruts, but the ground is too slippery for me to walk on in the wet spots.
but, inside the truck, I never felt a thing, those street treads ( Michelin LTX Defenders ) just went right up the hill.
if you look real close, the right rear wheel slips in the mud, and about 18 inches later, the driver side wheel catches hold and pulls ahead, and that repeats all the way up the hill.
it ain't an Air or Electric Locker, but it is the Best thing for us City folk who never go Rock Climbing.
the tracks to the far Left are where I went down the 15 degree hill to the highway.
Since Michelin LTX M/S tires got me stuck a few years ago, I've stuck with BFG All-Terrains and fhey haven't let me down on or off road. I did Cooper AT3 XLTs for awhile and they worked well but you can't beat the BFG All Terrains.
i contemplated the same on the F150, the regulars who hang out at one of the 4WD shops here in Kanagawa recommended against it, and instead suggested the air locker or the E locker. reason being that when driving in soft sand, or snow (low to medium speeds) and turning the truck will not want to turn properly and it causes all kinds of headaches for the driver. thats why I went with the ARB in the F150.
I'm sure you could install some additional wheel spin sensors, input to some Arduino based controller, control front E-locker.....You. Can. Do. It!!!
ng19delta
15
10-03-2016 07:18 AM
