a mild off road build
Old Feb 20, 2014 | 11:13 AM
jay_blu's Avatar
jay_blu
This highboy has been in the family a long time. My parents moved so they gave the truck to me if I came and got it. Since I left home the truck has only been driven one or two times a year at most, no real maintenance done. It got 8 mpg for the 300 miles I brought it to its new home.
1977
F250
4wd
390fe
4speed
I went to turn around in my field to get a load of wood and the truck sunk... 5 stuck trucks latter we got or neighbor with his skidder to pull us out. An older chevy showed up and pulled out a few trucks. It was a fun weekend, but I want my truck to do the pulling out.
To start with I would like new tires off road mud I don't drive it on the street much at all. Maybe a locker kit for the rear or limited slip diff.
What are your opinions on making this truck handle my farm mud.
Old Feb 20, 2014 | 11:28 AM
jay_blu's Avatar
jay_blu
I'm doing this on my phone since my work computer blocks the longin page, bare with me please!
Old Feb 20, 2014 | 03:28 PM
61steven's Avatar
61steven
What is your budget on this build?
There are two main ways to get more traction in mud. Lockers and tires.
As far as lockers go, you can forget limited slips. In really slippery situations you are essentially left with one drive wheel per axle. A locker "locks" both axle shafts together giving twice the traction. There are manual selection lockers like ARB and OX lockers that let you manually change from open diffs to a spool.
Automatic lockers like Detroits and lunchbox lockers automatically lock when in low traction situations. In the detroit, no wheel is allowed to spin slower than the ring gear. But in a corner one wheel can spin faster and "ratchet". If they were locked full time it would cause excessive tire wear and poor handling characteristics.
Find out what your truck already has. If you have open diffs wth spider gears, lunchbox lockers can be installed in your drive way for less than $500 front and rear. If you have a factory limited slip, you will need something like an ARB or Detroit to replace the stock carrier.
Aggressive mud tires will help out quite a bit too!
Old Feb 20, 2014 | 04:02 PM
jay_blu's Avatar
jay_blu
Im pretty sure I have open diff's. I guess I need to pull the pumpkin cover to see and find out how many splines my axles have. The detroit auto lockers seam like a good point to start. I found some 35x12X16.5 bfg mud terrains I might get with wheels.
Do 35" tires fit this truck ok with out a lift?
Old Feb 20, 2014 | 04:09 PM
61steven's Avatar
61steven
Double tap..
Old Feb 20, 2014 | 04:15 PM
61steven's Avatar
61steven
Sorry I skipped over the f250 part.
35" tires should fit with minimum rubbing, if any.
Old Feb 20, 2014 | 07:22 PM
79FordBlake's Avatar
79FordBlake
No lift needed to put 35's on a highboy.
Old Feb 21, 2014 | 10:37 AM
jay_blu's Avatar
jay_blu
So those pics didnt work with dropbox. Here they are with photobucket.
Old Feb 21, 2014 | 11:52 AM
castone001's Avatar
castone001
good lord you were STUCK
Old Feb 23, 2014 | 07:18 PM
jay_blu's Avatar
jay_blu
I found the solution! I bought a good running 79 f250 4x4 lifted on 38's with a 429 for $500. It yanked out the 77 pretty good. I also made a few passes through the mud/lake in my field. I broke a u joint but got it fixed and played some more.
Old Feb 23, 2014 | 09:22 PM
61steven's Avatar
61steven
Id love to have the luck to find a $500 dent with 4wd! Especially a 250! Congrats on the find
Old Feb 23, 2014 | 09:35 PM
jgavac's Avatar
jgavac
Loving those headlights
brandon_oma#692
Jun 7, 2018 08:37 AM
00t444e
Apr 8, 2018 08:23 AM
cOpE!
1978 - 1996 Big Bronco
Oct 8, 2010 06:12 AM
A1C DiMaggio
Apr 24, 2010 02:03 AM
79_ford_400_guy
17
Apr 24, 2002 07:06 AM
