Weird things happening
Old Nov 25, 2003 | 11:27 PM
Brian79150's Avatar
Brian79150
Question Weird things happening
I have a 95 7.3. When I start it the engine idles ruff for a 5 sec or so period then goes to normal. It seems to idle slower than normal too. Sometimes when Im driving, it will all of the sudden cut out for a second then back to normal...Finally, it was idling ruff when I would let off the pedal to come to a stop (45 miles an hour, let off pedal, no engine noise, then ruff idle, then when I get rolling slow it idles normal. Iv searched and cant seem to find anyone having the same problems. Any info is greatly appreciated.
Old Nov 26, 2003 | 01:29 AM
HoseDog's Avatar
HoseDog
I've experienced both of those. Seemed to have solved the "cutting out" with a new cam position sensor. Mine usually idles rough for a few seconds after a hot start, and sometimes when I come to a stop. This has been going on for several years. I've gotten used to it.
Old Nov 26, 2003 | 07:22 AM
f350xlt460's Avatar
f350xlt460
i noticed something similar on my truck when pulling a trailer cross country. As i was slowing down on the off ramps (foot off go pedal) and then pressed the clutch in, the engine seemed to drop down below an idle for a second then come back up. Little unnerving the first few times, but got used to it. Seemed that if i didnt let the engine slow me down some, the problem didnt happen. I havent done anything about it since then.
