Sterling 10.25 question
Old Apr 24, 2024 | 02:51 PM
86bullnose4x4's Avatar
86bullnose4x4
I recently purchased a disc brake conversion from lugnut4x4 for my 86 F250. I'm planning on doing a powerstroke swap in the this truck and I was thinking about swapping the rear axle with a newer (94-97) sterling 10.25. My question is is there any difference between the older axles and the newer axle that would prevent me using the disc brake conversion on the newer axle instead of the older axle? I hope this makes sense...
Old Apr 24, 2024 | 08:03 PM
tecgod13's Avatar
tecgod13
At some point they changed the design of the pinion and maybe the bearings due to issues of the pinion loosening up on the older axles. I am not sure when they made that change. I don't know of anything that would change the brakes.
Old Apr 25, 2024 | 01:21 AM
Prototypemech's Avatar
Prototypemech
As far as I know, they all used the same bendix rear drum brake setup. Hopefully they're interchangable.
RPhil
Nov 18, 2021 09:06 AM
twistedfreak
Ford Truck Parts for Sale
Aug 27, 2011 12:36 AM
Trickedout420
May 12, 2007 01:31 AM
AnOldDog
Dec 29, 2005 04:31 PM
