solid axle conversion question
Old Apr 30, 2007 | 04:52 PM
Trickedout420's Avatar
Trickedout420
i found an f250 solid axle, has the leafs and all, i was wondering if it would be possible to swap all this over under my f-150
its a solid axle if it uses the leafs right?
Old Apr 30, 2007 | 08:41 PM
ReAX's Avatar
ReAX
Anything is possible, you will need to add leaf spring mounts to the frame.
One thing to consider is your front axle will be 8 lug and your rear will be 5 lug. It will make rotating the tires a little difficult.
Old Apr 30, 2007 | 09:29 PM
Trickedout420
ill be replacing the back axle aswell
Old Apr 30, 2007 | 09:30 PM
ReAX's Avatar
ReAX
So you will just need to line up the axle, get it square and install the related bracketry.
Old May 1, 2007 | 05:48 AM
QA Guy's Avatar
QA Guy
Not all F-250 had solid axles up front, not sure what years.
Old May 11, 2007 | 11:26 PM
fancygem's Avatar
fancygem
some f250 ifs had leaf springs may not be a solid axle
Old May 12, 2007 | 01:31 AM
andym's Avatar
andym
Depending on how much fabricating you are willing to do, it may end up being a lot of work. What year is the donor truck? Is this going into you 1991 F-150?
Note that F-250's made from 1980 to 1998 use a TTB front axle and aren't solid.
