Engine or Transmission
Old Apr 29, 2024 | 07:11 AM
happylogan1's Avatar
happylogan1
Yeah, well. It’s getting to the point of repairs, repairs. But I would like to gold onto this truck for myself and when our tween gets license 4 years.. This year $ 7-8k already; however I did upgrade the radio- whoop-de-do! Most likely get it in for a diag- move on from there. I do need road worthy transpo for our roadtrip this summer to the UP- Michigan.
Regards,
Dave
Old Apr 29, 2024 | 07:45 AM
charlie g's Avatar
charlie g
FTE Community Team
have a trans shop check it out dave. if they give you bad news, one step at a time, just remember having 240k on it, isn't on your side, as many of those we see have blown at 65 to 80, than 240k shows how easy you have driven and cared for that truck
good luck
Old Apr 30, 2024 | 07:35 AM
explorerdriver's Avatar
explorerdriver
A scan tool could easily diagnose a converter. There is Lockup commanded, commanded slip and actual slip and difference PIDs. You do have to know what to look for. Sometimes it is OK to have a large difference.
Also if you can check Mode $06 data on a scan tool. It watches the cylinders and will pick up even one misfire. CELs only set if it "pollutes" past a threshold, which can be 100s of misfires.
It works very well on the 4V V8 engines, even back to the 95 I have.
JRS2
Jun 30, 2015 10:21 PM
BocceMon
Dec 24, 2014 04:24 PM
catfishin_welder
1997 - 2003 F150
Nov 11, 2014 06:36 PM
RoushFan00
2004 - 2008 F150
Feb 1, 2011 01:19 PM
snowmobiler7c
15
May 3, 2009 01:21 AM
