Stock rear trailer plug color codes
Old Apr 22, 2024 | 06:04 PM
Xmobile's Avatar
Xmobile
4wd Low
Hey guys, I got two new connectors plugs to mate to the two stock trailer receptacle connectors tucked over the rear bumper area. One plug (black) has 4 wires for brake / hazzard and L/R signal lights. The other connector (gray) has 3 wires (one is blue for the brake controller feed) and the other two, I can't figure out what they connect to. Does anyone have a color code of what those other two wires go to? One is green with black stripe and the other is orange with black strip. It might be Black with Green stripe and Black with orange stripe. I can't see enough of the wires to tell which is the base color and which is the stripe. The 4 wire plug (black one) is wired up to all the lights on my 7 blade trailer receptacle and all lights work fine. The 3 wire (gray plug) has the blue wire hooked up to the trailer brake feed on the 7 way (that works fine as well), but those other two are left hanging and I don't know what they're supposed to be connected to? Here is a picture of those two unconnected wire (blue circle). What I do (think I know) is that both the gray 3 wire connector and the black 4 wire connector is part of the tow package for our OBS trucks. This one is a 1992 F350 7.3 ZF5 crew cab dually.
In this pic is the gray 3 wire plug. The two wires are in the blue circle.
Old Apr 22, 2024 | 09:09 PM
TobyB's Avatar
TobyB
I think orange was battery voltage to charge a secondary 'house' battery on a travel trailer...
I forget the black/green: backup lights?
t
TC-Countryboy
All Things Towing
Apr 19, 2016 12:24 AM
metriccar
All Things Towing
May 1, 2012 06:40 PM
MAS1866
All Things Towing
Sep 19, 2010 09:44 PM
Tattooed_countryboy
Electrical Systems/Wiring
Feb 18, 2008 07:02 PM
rog22
All Things Towing
Apr 22, 2003 10:07 AM
