compression test....fuses?
Old Apr 20, 2024 | 12:43 PM
wwracer's Avatar
wwracer
I lost a cylinder on my 99 7.3 this past winter, looking to do a compression test today before I swap it out. Any fuses to pull to keep current draw to a minimum during the test?
Old Apr 20, 2024 | 12:57 PM
cleatus12r's Avatar
cleatus12r
Butt-Head
Just make sure the transmission is in neutral or park and use a jumper wire on the fender mounted starter relay. Nothing else has to be on.
If you must use the key switch, pull the PCM diode from the underhood fuse box. This will keep the fuel pump and glow plugs from being energized.
Old Apr 20, 2024 | 07:25 PM
wwracer's Avatar
wwracer
Key off....DUH... Geez I'm asking some dumb questions lately
99f350cclb
22
Dec 17, 2021 11:42 AM
therigwelder
Dec 30, 2016 08:56 AM
RANGER589
Sep 3, 2010 10:02 AM
Border3899
Dec 18, 2002 01:33 PM
