1978 - 1996 Big Bronco
seat belts
Old Nov 25, 2003 | 08:40 PM
NJbronco138's Avatar
NJbronco138
seat belts
My drivers side buckle has called it quits. I want to replace it, does anyone know what size torx bit that bolt is? Also does anyone know if there is an after market place to get a new buckle? I checked jcwhitney but the buckles they generic and I would like one that is a match. thanks in advance
Old Nov 25, 2003 | 08:46 PM
steve83's Avatar
steve83
T-50, and junkyards aren't allowed (by law) to sell seat belts, airbags, or catalytic converters. Get one from your local junkyard. The dealer will probably want over $100 for it.
Old Nov 25, 2003 | 09:12 PM
NJbronco138
thanks steve, Its 70 bucks from ford. I went to the Junk yard first yesterday, no luck the ones that might have worked were in bad shape or not coming out. I can't even get that bolt loose on my belt with on of those wrenchs I am going to go to sears and see if I can get a torx socket so i can use a breaker bar.
Old Nov 25, 2003 | 09:26 PM
steve83's Avatar
steve83
Spray some Liquid Wrench (or other penetrating oil; NOT WD-40) from the underside of the truck to lube the tip of the bolt. It's covered with undercoating/rust/mud, and the bolts are oversized anyway so they don't back out of the nuts over time.
Old Nov 25, 2003 | 09:29 PM
NJbronco138
Will do, thanks Steve
Old Nov 25, 2003 | 11:47 PM
BroncoRoadKill's Avatar
BroncoRoadKill
Hey I like WD-40, whats wrong with WD-40?
Old Nov 26, 2003 | 07:10 AM
steve83's Avatar
steve83
Well, he's a great guy & everything, but I don't think much of it as a lubricant OR a penetrant.
