Autozone lists a rotor only for $33 and a rotor with integrated spline hub for $69. I have not removed my setup comepletly but I can see a line where maybe they (long portion with Torx end and rotor) can come apart on the truck. Which should I get so I'm not making two trips? Is the rotor assembly one piece or two?
its a two piece setup that usually has to be pressed apart/together. Most places will press it on and then cut it in case of any warpage while pressing. I strongly reccoment against those cheapo ones, as they are often prone to rapid warping. I personbally prefer to cut the stock when possible, or splurge for the brand name rotors. Had a set of those inexpensive ones and warped em without even towing a trailer after a short period of time, and had to do the job again.
well, they dont "NEED" to be replaced at the same time. The calipers should adjust themselves to the sightly different thicknesses in the rotors, and you braking will be even between the two sides.
Click my signature and look in the Brakes & Hubs album - it shows exactly how the hub & rotor fit together. The integrated one is for '87-early'88 only, with flange-type hub locks.
Considering the low cost of the rotors, I'd replace the pair. You know you're gonna have to do the other one soon anyway, and you'll already have all the tools out, and you'll already be greasy & dirty...
i agree with steve83 they are cheap and you are already dirty so replace them both. yoiu dont have to but again you are already in there. now if you were to do the rears the drums have to be within 20 thousands of each other or you will notice and feel a brakeing sway from the back.69.00 will save a lot of work but you labor is cheap and it is not that complicated to change just the rotors.
OK, I pulled the automatic hubs out and now I need some special tool. I just want to replace the rotors. Jesus. Is it just that one special tool needed? A locknut wrench?
I just replaced my rotors , (Autozone rotor & hub assy), and replaced my bearings. The only special tool I bought was the spanner wrench. I decided to buy since I knew I was going to use it again when I replaced my ball joints and got new hubs. The rotors have held up nicely and since I put them in I have hauled a horse trailer to Texas and back to colorado, (loaded on the trip back), went hunting hauling a 30 ft camper, fourwheeled, and drive 50 mi. everyday round trip to and from work. No warpage yet. You dont have to replace the bearings but since you have em off, may as well do it anyway.
