Coolant dripping!
Old Apr 19, 2024 | 08:14 PM
wwwheaty's Avatar
wwwheaty
Coolant dripping!
1992 E350 7.5 started dripping coolant from front of engine. Source has not been identified. Not sure if it’s the pump or bypass hose or hopefully just a hose clamp!
Will loosening the radiator cap reduce amount to buy me more time?
Old Apr 20, 2024 | 09:12 AM
wwwheaty's Avatar
wwwheaty
It’s not the front but rather the forward drivers side. It’s darn hard to see in there.
Old Apr 21, 2024 | 09:50 AM
Bruce51's Avatar
Bruce51
Possibly the timing chain cover gasket. It's a very thin gasket and will develop a link about half way up the sides.
Just one more place to look beside the water pump vent hole or the thermostat housing.
Good luck!
Bruce
Old Apr 21, 2024 | 08:14 PM
wwwheaty's Avatar
wwwheaty
How do I get my eyes on these locations? Mirrors?
Old Apr 21, 2024 | 09:35 PM
econo93's Avatar
econo93
Remove the air cleaner. Get a bright flashlight and look around.
Old May 1, 2024 | 09:02 AM
wwwheaty's Avatar
wwwheaty
So it’s definitely on drivers side. Behind the water pump and not the water pump. Higher than the water pump. Can’t see anything from above. It leaks most when cold and slows down when hot. What else is on the drivers side? (I don’t want to hear the head….)
Old May 1, 2024 | 09:28 AM
tabijan's Avatar
tabijan
There are coolant passages in the forward part of the intake manifold that continue into the head. There might be a temp sensor or two towards the driver side of the intake manifold.
Borrow or rest a pressure tester, remove the air cleaner and hoses to the throttle body and have at it. Most chain auto parts stores have loaner tools.
Sixto
07 E350 5.4 198K miles
BKSinAZ
2004 - 2008 F150
Nov 2, 2014 03:25 PM
Ian123
Jul 4, 2011 12:40 AM
93 mix 'n match
1997 - 2003 F150
Oct 29, 2010 11:50 PM
Mic_bug
Jan 16, 2006 02:12 PM
alk3myst
1978 - 1996 Big Bronco
Aug 11, 2003 12:21 PM
