solenoid wiring
Old Nov 25, 2003 | 08:20 PM
pheens's Avatar
pheens
solenoid wiring
Just bought an '87 ranger fuel inj. need to figure out wiring for the solenoid. Thanks for the help.
Old Nov 25, 2003 | 08:26 PM
Dealford's Avatar
Dealford
Welcome to FTE pheens. Which engine is in your Ranger?
Old Nov 25, 2003 | 08:27 PM
Ken00's Avatar
Ken00
Welcome to FTE!!!
Do you mean the starter solenoid? If you do, the positive battery cable runs to one large post and the wire to the starter connects to the other largs one. The small one is from the ignition switch and when power is applied from the ignition switch it closes the starter circuit.
Old Nov 25, 2003 | 08:38 PM
pheens's Avatar
pheens
4 cyl. There are two large posts on the starter solenoid. I am confused as which wires go with the pos. battery cable and the neg battery cable
Old Nov 25, 2003 | 08:46 PM
Ken00's Avatar
Ken00
The post on the side closest to the battery gets the cable from the positive battery post, the one facing the back of the truck is connected to the cable that goes to the starter. The negative cable does not go to the starter solenoid, the starter is grounded to the block internaly.
nothercrash
Mar 10, 2014 08:57 PM
rwk26164
1997 - 2003 F150
Dec 24, 2011 03:35 PM
msquared100
Sep 22, 2010 08:40 AM
marcford
Electrical Systems/Wiring
Apr 10, 2006 11:16 AM
nitro94
May 10, 2002 08:54 PM
