Sponsored by: Real Truck
Seat moves when key inserted ?
Old Apr 19, 2024 | 11:01 AM
12F350's Avatar
12F350
Hello,
2012 f350,
not sure which part to change. Ignition switch, immobilization module ( goes around key cylinder assy) or lock key cylinder.
symptoms-
door open with key in, key not turned, sometimes will chime, sometimes not. If I VERY lightly push key towards column, it will chime. I let off, it stops.
upon putting key in, (no twist) seat moves.
upon putting key in and lightly wiggle, dash lights flicker and seat moves spastic.
fault code: B10F1
anyone know of the most likely culprit? I’m guessing the key cylinder due to how sensitive it is to the minor key movements that create a reaction.
Thoughts?
Old Apr 19, 2024 | 11:02 AM
12F350's Avatar
12F350
Also, no start issues. No key sticking or difficulty removing.
Old Apr 19, 2024 | 03:39 PM
ifrythings's Avatar
ifrythings
Power seats with memory function and “Easy entry and exit” is enabled, the seat will move back 2” when the vehicle is turned off and move 2” forward when turned on, or could also be using the key ID to set the seat back to memory set position.
If you don’t have memory seats then I’m not sure why it would be moving.
Kountryguy
Nov 24, 2023 02:31 PM
NathanEHarvey
General Automotive Discussion
Aug 31, 2016 01:07 AM
BCM
Oct 13, 2011 01:45 PM
Blujay96
May 4, 2010 07:47 PM
Mine2go
Mar 4, 2007 06:22 PM
