Heater Core Replacement
Old Apr 19, 2024 | 12:20 PM
Max Capacity's Avatar
Max Capacity
Would this work ? Call them.
https://www.summitracing.com/parts/r...0205/make/ford
I have found Summit has great customer service.
Old Apr 19, 2024 | 12:35 PM
BigBlue2's Avatar
BigBlue2
Looks correct...but. I would call them. Amazingly you can speak to a human being. They have flat rate shipping so fill your cart with everything you think you'll need for the next year!
Great company, great customer service.
Old Apr 19, 2024 | 04:37 PM
Cerran's Avatar
Cerran
I need a new carb too so I'll poke around and call them.
Old Apr 19, 2024 | 07:14 PM
Franklin2's Avatar
Franklin2
I wonder if you could use a heat gun and modify the original housing enough for it to fit.
Old Apr 19, 2024 | 08:03 PM
FuzzFace2's Avatar
FuzzFace2
I did not look over the link that was posted but I ran into this on my factory AC truck also.
I bought a core and had it for months before I got around to install and also found it was the wrong shape.
Because I had to use the truck and was still cold out so needed some heat.
I ended up removing all the foam seals and forced the core into the box just to use the truck.
I did find the right one on think Amazon and took a long time to get but was the right one.
IIRC the part numbers are different between what you can get in stores and the right one.
I have had it for months also and hope I can find it to get the PN from it.
I also think the right PN has been posted in the forums too.
Dave ----
Old Apr 19, 2024 | 09:17 PM
Cerran's Avatar
Cerran
Dave ----
I spoke with Summit racing today and it looks like they have the correct one in stock. When I order it and verify I will let everybody know and put up the part number.
i’m also going to order a new quick fuel carburetor for the truck since the old one has been given me some trouble. Maybe I can do a tutorial on the swap once I get completed and I’ll take some pictures.
This rounds out the maintenance I need to do on the truck for this year. Trying to get it ready for woodcutting season.
Fleetsuper
Oct 16, 2023 08:59 AM
PintoGuy
May 29, 2021 04:44 AM
ryanthepaintballer
Bronco II
Oct 6, 2010 09:19 PM
don_79f250
Dec 13, 2004 07:32 PM
