427 oil pan help
Old Apr 18, 2024 | 08:30 PM
87saleen's Avatar
87saleen
3rd Gear
427 oil pan help
I'm installing a 427 fe in a 1972 ford f250 camper special and am trying to find a 7 quart oil pan that will fit
Old Apr 18, 2024 | 09:21 PM
85e150's Avatar
85e150
Front sump?
Any FE or FT pan will bolt up.
Old Apr 19, 2024 | 09:17 AM
87saleen's Avatar
87saleen
3rd Gear
the issue is that most 7 quart pans are either to deep or to wide
Old Apr 19, 2024 | 09:59 AM
'65Ford's Avatar
'65Ford
For more oil capacity, an FT or an FE 4wd pan might fit the truck. (Top photo is for an FT). Like the OP said, I believe the cross member and/or the steering linkage might interfere. And you may have to fabricate a baffle system and a place for a dipstick.
Fwiw, I use a standard volume and pressure pump with oil restriction to the heads and the 2wd pan. I tow and haul but don't do hard acceleration or take the curves real fast so 5 quarts of oil is sufficient.
CarterE
Mar 1, 2022 09:21 AM
Rusty_S
Offroad & 4x4
Aug 10, 2019 07:47 PM
