Help. 97 7.3 no start.
Old Apr 17, 2024 | 07:36 PM
tobyblank's Avatar
tobyblank
2nd Gear
New to the diesel world and also this web. I bought a 1997 7.3 with 199k miles a couple months ago, eventually found out I got absolutely burnt on it but that’s besides the point.
I’m going to explain every detail up to this point.
one day in about 65° weather I was letting it warm up before leaving the house, it started shaking and idling rough worse and worse til it shut off. Now that I think about it, like it ran out of fuel (hm).
oil pressure gauge goes up, RPMS show. Fuel gauge doesn’t really work too well. Only has front tank.
New CPS, ICP, tried starting after unplugging tuner, charged both batteries up, changed oil. All fuses good. Only DTC is for EBPV which is deleted.
eventually found the fuel bowl only had about a 1” of fuel in it. Cranking truck over, it will not fill fuel bowl up. Filled up manually and it will blow white smoke and hit a little more than usual, but not start.
tank has about 1/2 to 2/3 of fuel.
Based off of my diagnosing, I believe the next step would be to blow out fuel lines, clean IPR screen or possibly drop tank. What do you guys think? I’m losing interest fast and need someone with similar situation.
Old Apr 17, 2024 | 08:31 PM
Edgethis's Avatar
Edgethis
You've covered alot of the common questions. Does the fuel bowl fill when cranking? You mentioned it was low and you manually filled it.
Smoke is good out the exhaust, means most everything up to that point is working. I know you said its 65*, but its possible the glow plugs are bad. It's possible the oil and engine were colder from sitting. Have youbtroed plugging the trucks block heater in a for awhile and then try cranking?
Old Apr 22, 2024 | 12:13 PM
knottyrope's Avatar
knottyrope
Sounds like pump failed or suction line is leaking
Bowl needs to be full or injectors wont get much fuel, injectors can suck some fuel and run very weak making for a hard start
Norman Williams
Oct 19, 2022 10:42 AM
Texasdeereandhorse
21
Oct 26, 2016 01:37 PM
bruno2
Jul 2, 2015 04:42 PM
cowboy51
Jan 15, 2010 06:03 PM
bubbagilkes
Oct 13, 2009 08:45 PM
