Is Phaser knock only when hot?
Old Apr 17, 2024 | 02:51 PM
dbuck50's Avatar
dbuck50
I think I have phaser knock on my 2006 FX4 5.4L w/134,000. I hear the knock in the front area of the passenger side valve train. The thing is, all I have read/viewed has been that phaser knock is only when hot and not cold? I hear it from when it is started up when the idle returns to 600rpm of so. If I give it any gas and get it to 1000rpm, it goes away...which leads me to believe it isn't a lifter/roller follower. Runs fine and no rattle on startup. Is phaser knock on a cold engine possible? its no worse when its warmed up, pretty much always the same level of knock sound at low rpm.
Old Apr 17, 2024 | 03:47 PM
WWR's Avatar
WWR
Not chain slap?
Old Apr 17, 2024 | 09:08 PM
dbuck50's Avatar
dbuck50
no, definitely a tap and not chain. doesn't change whether the engine is hot or cold, so not an exhaust leak either.
Flip4ford
Kansas Chapter
17
Aug 19, 2019 06:23 AM
Teutonics
Nov 1, 2017 02:01 PM
FxRiZBeAsTLy
Oct 31, 2010 02:53 PM
slc10844
Oct 18, 2005 07:53 PM
