Ford 3 Door Heater help
Old Apr 16, 2024 | 09:40 PM
BBF4's Avatar
BBF4
I aquired a three door aftermarket heater for my truck. With it came the controls. The downside is I have four wires coming off the motor and no idea how to wire it to the switch/battery. Does anyone have a schematic?
Old Apr 16, 2024 | 10:56 PM
bmoran4's Avatar
bmoran4
Parts Nerd Extraordinaire
This may be close enough:
Old Apr 17, 2024 | 03:50 AM
FortyNiner's Avatar
FortyNiner
A slightly clearer version of the reference from bmoran.
File Type: pdf
Old Apr 17, 2024 | 04:37 AM
bmoran4's Avatar
bmoran4
Thanks for sharing that - I did not have that reference!
Old Apr 17, 2024 | 06:10 AM
BBF4's Avatar
BBF4
How do I know which wire is which coming from the motor? Is there a way to test with a multimeter?
Old Apr 17, 2024 | 08:00 AM
mtflat's Avatar
mtflat
Can you identify the color of the wires coming from the heater? Are your motor contacts similar to the above? In the diagram it shows a red, yellow, brown and red with black tracer and their corresponding connections.
Old Apr 17, 2024 | 08:04 AM
BBF4's Avatar
BBF4
Originally Posted by mtflat
Can you identify the color of the wires coming from the heater? Are your motor contacts similar to the above? In the diagram it shows a red, yellow, brown and red with blue tracing and their corresponding connections.
yeah all the wires look the same! Totally crazy. I will post some pictures later.
Old Apr 17, 2024 | 08:05 AM
bmoran4's Avatar
bmoran4
First, the wires should be colored per the diagram:
1G = First Wire, Green Color, Short Field Wire
2R = Second Wire, Red Color, Forward Brush Wire
3Y = Third Wire, Yellow Color, Long Field Wire
4Br = Forth Wire, Brown Color, Reverse Brush Wire
5RB = Fifth Wire, Red/Black Color, Fuse Box (Power)
If the colors are faded or indeterminate, the instructions go on with these 6 steps:
1. ATTACH POSITIVE BATTERY POST 6V LEAD TO ANY OF 4 HEATER MOTOR WIRES-MASKING TAPE THIS LEAD AS (GROUND) (G).
2. TOUCH NEGATIVE BATTERY POST 6V LEAD TO REMAINING (3) WIRES UNTIL SPARK OR GROUND FLASH OCCURS ISOLATE WITH TAPE MARK (FIELD) (Y).
3. THEN ATTACH NEGATIVE 6V LEAD TO EITHER OF THE (2) REMAINING WIRES - MARK (1) WIRE (FORWARD) (R), REMAINING WIRE (REVERSE) (BR).
4. TOUCH FIELD WIRE (Y) TO REMAINING WIRE REVERSE (BR) MOTORING SHOULD OCCUR IF THE MOTOR IS GOOD.
5. ROTATION, SWITCH NEGATIVE LEAD TO LAST WIRE (BR) AND TOUCH FIELD WIRE (Y) TO (FORWARD) (R) WIRE AND MOTORING SHOULD OCCUR IN OPPOSITE ROTATION.
6. LOW SPEEDS ARE CONTROLLED BY RESISTANCE WIRE COIL ON THE HEATER SWITCH.
Old Apr 17, 2024 | 08:15 AM
BBF4's Avatar
BBF4
Thank you very much!
Old Apr 17, 2024 | 08:47 AM
BBF4's Avatar
BBF4
I do have another curiosity question. I see they say this heater has a reversible motor….what would be the benefit of that? What could that allow the heater to do different?
Old Apr 17, 2024 | 09:22 AM
FortyNiner's Avatar
FortyNiner
The motor reverses for defrost mode.
Old Apr 17, 2024 | 08:47 PM
BBF4's Avatar
BBF4
Thank you very much for this! All the wires were the same color so I followed your instructions and I have all the wires figured out. I was quite proud of myself for being able to follow your instructions. So another question. When talking about forward vs. reverse. When looking at the end of the motorshaft head on...if the shaft is turning clockwise, is it running forward or backward?
Thanks again!
Old Apr 18, 2024 | 08:59 AM
mOROTBREATH's Avatar
mOROTBREATH
^^^It would be easiest to determine this by simply turning it on. Test each setting.
Old Apr 18, 2024 | 09:37 AM
BBF4's Avatar
BBF4
Agreed just trying to see if someone knew so I wouldn’t have to redo wiring if I guessed wrong.
Old Apr 18, 2024 | 05:14 PM
Moe Craig's Avatar
Moe Craig
Pic of what you got!
