Sponsored by: Auxito
Need help diagnosing
Old Apr 16, 2024 | 04:17 PM
Champmicah's Avatar
Champmicah
4wd Low
I have a 2000 Ford f150 4.2 engine ,195k odometer.. Manual transmission
The issue I'm having is that as I'm driving the vehicle when I reach a certain speed in first gear I can get up to about 5 mph and then the car will start jerking violently. When I go up to 2nd gear I can make it to about 10 mph and then the car will start shaking violently. When I shift the vehicle to third gear I can get to about 20 miles per hour before it starts shaking violently. In fourth gear I can get to about 30 mph and it does the same thing. This morning on the way to work it was driving just fine and about 5 to 10 minutes from reaching my destination it started doing the violent shaking again I don't know if it's the catalytic converter or something simple like a sensor or something.
I've already replaced the purge control valve, as well as the EGR valve on the truck. I've also checked the spark plugs and replaced them.
Any knowledge or insight from you guys will be completely helpful because they already want $900 for a catalytic job on this truck and I cannot afford that.
Old Apr 16, 2024 | 04:20 PM
85e150's Avatar
85e150
Your truck is an OBDII model. You need to plug in a code reader and see what it says.
A bad cat won't cause what you're talking about.
From your description, it sounds RPM related--
Have you noticed if it's roughly the same RPM each time?
Any work to clutch or transmission?
Old Apr 16, 2024 | 04:22 PM
Champmicah's Avatar
Champmicah
4wd Low
I have a scanner and I'll use it to check the RPMs but if it is an RPM problem what are you suggesting
Old Apr 16, 2024 | 04:31 PM
85e150's Avatar
85e150
Does the scanner report OBDII codes? That's what we're looking for.
Once you have that, then the RPM issue can help with diagnosis.
Old Apr 16, 2024 | 04:40 PM
Champmicah's Avatar
Champmicah
4wd Low
Yes it does
Old Apr 16, 2024 | 05:24 PM
85e150's Avatar
85e150
Post the codes.
Old Apr 16, 2024 | 05:41 PM
Champmicah's Avatar
Champmicah
4wd Low
Post the codes.
P0300
P0320
P0455
P0401
P0174
Old Apr 16, 2024 | 05:57 PM
85e150's Avatar
85e150
P0300
Random misfire. I see you swapped plugs, what about COP or wires?
P0320
Engine speed circuit problem. Similar problem here:
https://www.ford-trucks.com/forums/6...e-jerking.html
Check connections, anything to do with ignition, including COP and related wiring
P0455
EVAP leak. Check gas cap and filler neck, plus charcoal cannisters and connections including all lines to intake for vacuum or fumes.
P0401
Insufficient EGR flow. Related post:
https://www.ford-trucks.com/forums/2...r-flow-26.html
P0174
Too lean. Check for vacuum leaks which could also be related to your EVAP issue.
https://www.ford-trucks.com/forums/7...ode-p0174.html
Old Apr 16, 2024 | 08:03 PM
Champmicah's Avatar
Champmicah
4wd Low
P0300
P0320
P0455
P0401
P0174
Could you spell out the "COP"
Old Apr 16, 2024 | 08:05 PM
85e150's Avatar
85e150
Coil over plug. I'm not sure you have those, but all connections in the ignition system should be checked.
Old Apr 16, 2024 | 08:06 PM
Champmicah's Avatar
Champmicah
4wd Low
I'll give it a look tomorrow, I'll tell you what I find, thanks for everything
Old Apr 17, 2024 | 07:06 AM
manicmechanic007's Avatar
manicmechanic007
Check your fuel pressure
The bucking and jerking sounds like low fuel pressure to me
Those codes are some trouble for I/M compliance, but are not the jerking problem IMO
Old Apr 25, 2024 | 05:02 AM
Champmicah's Avatar
Champmicah
4wd Low
Turned out to be the crankshaft sensor, drives like brand new now
Sepa Laverga
Dec 27, 2017 09:02 PM
Evergreen53
Apr 17, 2017 12:17 PM
seebeexee
Jun 9, 2013 09:32 PM
birdseye418
2009 - 2014 F150
Jul 8, 2012 08:26 PM
dbacklund
1983 - 2012 Ranger & B-Series
Nov 13, 2004 07:55 PM
