Comment on your 5th Wheel Towing Experience?
Old Apr 17, 2024 | 05:54 AM
99powerstrokedF250's Avatar
99powerstrokedF250
Originally Posted by Fox-BLUE1
One thing you might need to consider are air bags or something similar. These newer trucks seem to have more give in the springs. My 5th wheel pin weight is prob at 1250 and I needed bags to get the back end level on my 23.
If you have a pin weight at 1250 (which means it's an EXTREMELY light fifth wheel) and you're squatting that much, you've got broken springs on that F350. I think you have your weight estimated WAY wrong.
Old Apr 17, 2024 | 07:36 AM
jr_nicholson's Avatar
jr_nicholson
In short, no not at all
Old Apr 17, 2024 | 07:45 AM
mikeschiele's Avatar
mikeschiele
Trailering
I can only tell you my experience. I pull a 33ft 10k 5th wheel with my 250 6.7 diesel and I don’t even know it’s behind me. I have the standard rear end, I think 331. I live in California and pull it in the Sierra Nevadas.
the tongue weight is about 1750.
I usually go to US forest campgrounds and can usually find something but at 36ft I would definitely be more limited.
good luck on your venture.
Old Apr 17, 2024 | 11:32 AM
WXboy's Avatar
WXboy
Originally Posted by OBS460
The front area will make more of a difference than 1000lbs or even 5 more feet in length on the trucks ability to tow the trailer. If one is 3" shorter but 6" wider the frontal area is going to affect your fuel economy more and whether you had enough power to overcome that wind resistance with the power and gear ratio combination of your truck.
This.
People always overlook the frontal area consideration. On half-ton trucks, there are even limits on frontal area (expressed as square feet) that you can tow regardless of weight. My truck is a 6.7 diesel and last weekend I pulled a 8.5x20 enclosed trailer that was only 7k lbs. or so at the most. The truck got 8 to 9 MPG and had to downshift to 5th gear to pull hills. I was quite certain that a gasoline engine would have been screaming. Obviously the weight wasn’t high, it was just the fact that I was pulling a kite down the highway.
I know that there are guys dragging 15k campers around with these trucks all the time. But I find it very hard to believe that there is “plenty of power”. Maybe in Kansas on flat roads, but where I live and work and play any gasoline truck would be taxed heavily with that size and weight behind it and even the diesels have to really make some boost pressure to maintain highway speed.
Old Apr 17, 2024 | 02:01 PM
senix's Avatar
senix
I pulled this brick from PA to Miami Florida and although it was heavy and although I was going to a lower elevation I pushed darn near 20 psi boost the whole way
Old Apr 17, 2024 | 02:40 PM
fragmag's Avatar
fragmag
I towed a 11k 5th wheel with my '20 F250 7.3l with 4:30 and it towed like a beast. I upgraded to an F350 with the 6.7 HO and 3:31 and it tows way better. I also upgraded my 5th wheel to 14k lbs. The diesel tows better not just up hill but also better downhill. If you aren't dealing with steep grades then the 7.3 is awesome. I needed more payload so I upgraded to the 350.
Old Apr 17, 2024 | 06:22 PM
WE3ZS's Avatar
WE3ZS
She’s a beut Scott, did you trade up from the StoneRidge?
Old Apr 17, 2024 | 06:26 PM
senix's Avatar
senix
unique for sure, lots of looks and question during stops. look closely and remember your world history.
Old Apr 17, 2024 | 06:42 PM
WE3ZS's Avatar
WE3ZS
Is that a Central European “cattle car” from the late 1930/40s? Going to those “camps” is a world away from the camps we visit………
Old Apr 17, 2024 | 06:49 PM
Old_Soul's Avatar
Old_Soul
4th Gear
Is that from WWII that the Germans would have used?
Old Apr 17, 2024 | 07:25 PM
senix's Avatar
senix
yes it is. holocaust exhibit that I got an opportunity to move it.
Old Apr 17, 2024 | 08:19 PM
jim7044's Avatar
jim7044
First hand experience here, change your order to 6.7L diesel or very minimum to 4:30 rear end. I know your asking about the camper and not the truck.
6.7L fun easy going, power to spare, quiet enjoyable ride. 7.3 loud high rpms, constantly downshifts to hold highway speed with heavy load, no fun.
Old Apr 17, 2024 | 08:55 PM
  #28
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
Don't buy a diesel without adding the 200K diesel care warranty!
Old Apr 18, 2024 | 12:41 AM
  #29
Kameron Rice's Avatar
Kameron Rice
disagree, diesels are no more work then a gas truck, imo. Just change $75 fuel filter every 15k. Only need the extended warranty if your like me and working the **** out of it heavy hauling construction machinery around town, or like yourself doing hotshot work. Daily driving solo for commercial use, no warranty needed, or daily driving for personal use and towing the rv, no warranty needed.
same goes for a 7.3L gas apply the same rules.
Old Apr 18, 2024 | 06:33 AM
  #30
99powerstrokedF250
I mean this right here is truth - if you're not working it like a dog, and you're keeping up on maintenance, chances are you'll have very few, if any, major issues.
Out of all the vehicles I've ever owned, the most of the issues I've ever had have been electrical, sensors and wiring, or rust. My last truck had issues with the parking sensors and a failed MAP sensor. The truck before that had some chaffed wires, lost its FICM, and I had to replace the transmission cooler lines because they rusted through. The truck before that had the glow plug relay die and the blend door motor crap out (that was probably the most trouble-free truck I had). So on and so forth. Sure I've had to do maintenance on them all (brakes, bearings, u-joints, etc), but as far as actual unexpected problems? Almost all electrical.
Take care of it, and it'll take care of you.
