Oil canister/filter 239.
Old Apr 16, 2024 | 09:46 AM
Matt1966's Avatar
Matt1966
Hi! I could finally start her up after some work with the cooling and charging. I am going to change the engine oil. It's the first time for me with the 239 so just want to be sure. I drained the oil and removed the oil filter. It's quite a lot of oil left in the canister. Is it normal or do I have a problem with the return line from the canister?
Thanks!! Mats Nilsson, Sweden
Old Apr 16, 2024 | 10:03 AM
bmoran4's Avatar
bmoran4
Parts Nerd Extraordinaire
It is normal. If you are concerned, you can use a turkey baster or similar to remove the remaining oil and replenish the canister housing with fresh oil (along with the normal oil change in the crank case).
Old Apr 16, 2024 | 10:24 AM
Matt1966's Avatar
Matt1966
Thanks! Do I have to replenish the canister or can I leave the new filter "dry" in the canister?
Mats
Old Apr 16, 2024 | 10:36 AM
bmoran4's Avatar
bmoran4
It is simple enough to replenish, so why not?
Old Apr 16, 2024 | 10:43 AM
DieselDog409's Avatar
DieselDog409
helps shorten or prevent the "Dry Start" that people talk about.
Old Apr 16, 2024 | 11:03 AM
ALBUQ F-1's Avatar
ALBUQ F-1
A bypass filter doesn't need to be filled before the mains and rods get oil. Filling the canister won't do any good. It will fill up on its own just fine.
Old Apr 16, 2024 | 11:10 AM
Matt1966's Avatar
Matt1966
Yes, of course it's better to replenish before I start it up.
Thanks a lot! Mats
Old Apr 16, 2024 | 11:18 AM
bmoran4's Avatar
bmoran4
Not so with a bypass system that our trucks generally have. The oil in the canister filters back into the crankcase with out going through the engine. The oil that goes through the engine is diverted to the engine BEFORE the filter housing, like shown in these diagram and further discussed in the thread linked:
https://www.ford-trucks.com/forums/1...iltration.html
Edit: Others have chimed in at the same time with similar information.
Old Apr 17, 2024 | 05:25 PM
Don T's Avatar
Don T
And as a reminder to some that have the "tall" bypass filter that the wix 51006 filter does not work in these canisters. MOST parts search's will show the 51006 is good for all these 239 engines; but it will not work in the tall filter canisters This filter is almost 3 inches shorter than the correct tall one and the oil will simply go directly to the return tube and never enter the filter. The tall one I use is wix 51503. They are the same diameter and fit the center tube correctly but the 51006 is about 5 inches tall and the 51503 is about 8 inches tall.
Old Apr 17, 2024 | 05:57 PM
bmoran4's Avatar
bmoran4
@Don T , the larger canister you speak of is for Canadian trucks. American references lack that information.
Old Apr 18, 2024 | 08:30 AM
Matt1966's Avatar
Matt1966
I do think it's a little bit strange that my new Wix filter does not have the seal in the center of the filter like the old one. What stops the oil to go from the pressure side to the "return side" without passing the filter in the bottom of the canister? Thanks!
Old Apr 18, 2024 | 08:37 AM
bmoran4's Avatar
bmoran4
Mats,
If you look at your new Wix filter, it does have a seal, it just doesn't have a lip that protrudes above the top:
Old Apr 18, 2024 | 09:21 AM
Matt1966's Avatar
Matt1966
Yes, but the seal is almost below the flat metal surface on the filter and not above like the old filter. Maybe it seals different because the new filter is very tight to the pipe in the canister. I have not been able to slide it down the canister yet???? Mats
Old Apr 18, 2024 | 09:30 AM
bmoran4's Avatar
bmoran4
The filter only needs to be sealed to the pipe. It does not need to be sealed against the washer on the spring on the cap.
Old Apr 18, 2024 | 09:46 AM
Matt1966's Avatar
Matt1966
Yes, of course!!! I am very pig-headed when I dont understand the principles!!!! I thought both ends of the filter seals to the bottom and top of the canister!!!!!
Thats why the seal in the new filter is very tight to the pipe in the canister. I need engine oil on the seal and twist the filter to get the filter in. Thank you soooo much!!!
