Axle upgrades
Old Jun 16, 2024 | 07:08 AM
pilot31's Avatar
pilot31
F1 coyote, respectfully please give us more information regarding this c4500 knuckle change….
Originally Posted by F1 coyote
its a meritor axle, I measured the kingpin on the f7 and it matched to a meritor axle used on the c4500 trucks. try measuring the king pin on your f4 and see if it matches a modern axle. GOOD LUCK.
Old Jul 5, 2024 | 03:41 AM
F1 coyote's Avatar
F1 coyote
Im sorry it took me so long to get back to you , but the meritor axle is a MFS06151CNN3, the king pin kit is R201478. The new king pin has to be machined where the draw pin goes through to fit the new draw pin.
Old Jul 5, 2024 | 03:58 AM
F1 coyote's Avatar
F1 coyote
You could use the old draw pin, or go to a diesel shop and ask if they keep the have any used draw pins and get one that is the right size, one that you can bolt up. The drag link is the next step, you'll have to weld the original drag link to the drag link that goes with the meritor knuckles, it lines up well. Me I'm using the power steering box off a 97' Intertional 3800 school bus. I'm not sure if your engine will produce enough vacuum to work the brakes or not I'm using the hydraulic booster off the 3800 bus. If you go this way keep in touch so we know how its going.
1big79
18
Jan 11, 2006 07:32 AM
Christopher2
Feb 23, 2005 08:25 PM
Christopher2
Dec 1, 2004 06:45 PM
61WillysWagon
Jan 21, 2004 12:29 AM
bigin302
Feb 12, 2003 01:54 PM
