Sponsored by: Real Truck
Newbie needing help with 6.0
Old Apr 15, 2024 | 10:14 PM
Fishfan13's Avatar
Fishfan13
4th Gear
Hello, new to forum hoping someone can help. I have a 2003 6.0. About 7 years ago I installed a Pensacola Diesel HPOP along with OEM IPR and ICP. Truck has ran good and now I have a crank no start issue. Took the truck to a shop and they diagnosed a bad HPOP. I installed the Dieselsite Adrenaline slightly over stock HPOP. OEM discharge tube, OEM IPR, OEM ICP, Dieselsite EGR Cooler, XDP Oil Cooler, Updated Standpipes, HHC Fuel rail seals and the new HHC leak proof ball cups as well as OEM steel braided lines from the standpipes to the fuel rails. I also installed a new OEM fuel injection harness. Truck has a Sinister Diesel air intake upgraded alternators and 4 inch exhaust. Truck also has coolant filter system and updated FICM. I also installed the ICP relocation kit. With all that said, I still have crank no start. Using the scan gauge II, I get 47.5v and sync when cranking. The IPR is showing 84% and the ICP will only get to 260. When I unplug the ICP (ICP goes to 1500 and IPR to 45%) truck will not start either. I do have low pressure showing on the gauge and the oil filter housing fills with oil. I plugged air into the ICP port, and the only leak was one injector on the passenger side. I replaced that injector. I found a bad connection on the IPR pigtail fixed it and the truck started. Took the truck for a drive and the ICP was eratic bouncing from 650 to 1200 and the IPR stayed at 85%. Pulled into the driveway and truck died. Once again have a crank no start issue. Today I plugged the IPR into a 12v power supply and turned it on while cranking and the truck started right up. Removed the power supply and plugged IPR back in and get a crank no start. Then I grounded the ground side of the IPR and the truck starts. I know this is a pulsating ground and am not sure on how to check it. I did trace the ground wire back to the PCM and there is continuity from the PCM to the IPR. I replaced both relays associated to the PCM and checked all fuses. Also checked grounds in the engine compartment. I also went back though removed every crimp connector and soldered all of the connections and used heat shrink. At this point I do not know what else to check or if I just need to replace the PCM. Any advice will be appreciated.
Old Apr 16, 2024 | 06:10 AM
99powerstrokedF250's Avatar
99powerstrokedF250
Okay so you know it's an issue at the IPR, and that it's not getting/seeing 12v (you saw this when you put in a 12v power supply). Possible bad IPR, possible bad wiring (chaffed wire someplace). Going to have to check both. I wouldn't have moved on to anything else until that issue was solved.
Old Apr 16, 2024 | 10:27 PM
2004 F450's Avatar
2004 F450
Your getting help on your other post but your not responding to the comments or questions, probably not what you want to hear.
https://www.ford-trucks.com/forums/1...ith-6-0-a.html
Old Apr 17, 2024 | 05:59 AM
99powerstrokedF250
I mean, it's been 2 days, perhaps he just hasn't checked back in? But he does only have 2 posts, one here and one that was moved to the 6.0 forum...Most with similar answers.
I have noticed it seems that he's just throwing parts at it and hoping something sticks, but he definitely needs to troubleshoot those ICP/IPR issues first and foremost.
Old Apr 18, 2024 | 09:44 AM
2004 F450's Avatar
2004 F450
He also has a post on .org that Bismic referenced in his other post.
Fishfan13
Apr 20, 2024 11:28 AM
Jcimino2
Sep 22, 2020 09:19 PM
9Dark6
Aug 11, 2020 11:30 AM
BLaigle
Jul 10, 2019 04:04 PM
Schlu42
May 9, 2017 06:15 AM
