Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
air Brake Swap
Old Apr 15, 2024 | 01:46 PM
shaun.be's Avatar
shaun.be
air Brake Swap
Hello everyone,
How much of a project is it to swap a juice brake system to an air brake system? I'm looking at a 70s model f700 with a 361 and air brakes, Im really only buying the truck for the engine but It's still a runner and has a propane setup on it with air brakes. the truck that will receive the air system is a 68 N700. I'm wanting to swap axles anyway just to use a more modern 10 lug Budd wheel mainly for aesthetics plus availability, I know the 20s are available but most places have to order them in.
Thanks
Old Apr 15, 2024 | 04:45 PM
Destroked 450's Avatar
Destroked 450
The only possible issue you may have will be the brake pedal and foot valve mounting
I’m not sure if they are the same for both cabs
Take plenty of photos of the air tanks plumbing and any other valve plumbing
If the F-700 has single chamber brakes on the rear you’ll want to add the necessary valve and dual brake chambers to get sufficient parking brakes
On single chamber system when the air bleeds off you have zero brakes
Old Apr 15, 2024 | 04:58 PM
shaun.be's Avatar
shaun.be
I wasn't aware that there was only a single chamber setup with no spring brake in the rear, I'll have too look more into that.
I wonder if the foot valve is still available for an n series truck.
Jerryragon
Large Truck
Apr 10, 2024 08:36 PM
85e150
Mississippi Chapter
Sep 28, 2022 10:54 AM
SgtOtaku
May 29, 2018 07:53 AM
2speed
Large Truck
Apr 25, 2012 09:05 AM
Crete
Large Truck
34
Jun 22, 2011 03:07 PM
