Thunderjet / D4VE intake to sqaurebore carb
Hey everyone,
First time poster here, with a Sunday project that has inevitably turned into a multi-day struggle. I have a 460 in my 1972 F-250 CS that I am attempting to replace the carburetor on. To my understanding, the 770 CFM street avenger I bought has a squarebore design, each butterfly measuring ~43mm but the intake on my 460, I believe is a D4VE thunderjet intake, it's primaries are only ~40mm wide and secondaries are the ~43mm. I cant seem to find any plate adapter or gasket for the thenderjet's "almost sqaurebore" set up. How do I get these two platforms to mate/ function properly? or do I need to just spend the money on a aluminum intake? Any advice or direction is appreciated.
That intake would have been originally equipped with an EGR spacer plate between the intake and carb - note the round hole on the passenger side. That exhaust gas passage needs to be blocked off in some fashion. Best solution is to replace the intake manifold gaskets and use a thin stainless sheetmetal shim on the exhaust crossover passage to both heads (some sets used to come with that shim as an 'option'..Exhaust gasses are very corrosive, and will eat through any aluminum spacer/or adapter plate. OR you can use a four-hole stainless plate under some sort of insulating spacer under the carb. (yes, the crossover carries ~600° exhaust gasses through it!) The Street Avenger has an electric choke provision, so you don't need the exhaust crossover to heat those tubes in the 1/8" metal plate on the passenger side - which is why it is better to block those passages off at the cylinder head-to-intake gasket!
Ford used EGR systems starting in '73. My current two '73 Cougars with Q-code Clevelands (351C-4V) , and one of my '73 Cougar parts cars with a 351C-2V also had an EGR plate under the carb. The 4V version was made out of aluminum, and the corrosive exhaust gasses really did a number on them.
Even if the OP were to block off the heat riser (and EGR) passage in the manifold, that intake might not seal to a regular Holley 4-hole gasket. Best to use an four-hole adapter/spacer.
Yes, best solution is to use a different intake but there is no reason he can't block off the exhaust crossover passages from the cylinder heads like I had suggested, and use a regular four-hole spacer below the Holley.
The following users liked this post:
bowtie bruiser
08-10-2008 07:55 AM
f-4x4
04-19-2006 02:38 AM
Deerbowhunter
03-04-2006 08:38 PM
BumbleB
12-07-2004 10:52 AM
