Waze app?
Old Apr 12, 2024 | 09:34 PM
Edd505's Avatar
Edd505
Waze app?
I have a 2022 F350 with the sync4 system. I use the Waze app traveling and it works great on my Android phone. When I switch to the truck screen with Android Auto I get voice directions but I lose the highlighted route. Waze forum was no help, I was hoping someone else has had the issue and know how to fix this.
Old Apr 13, 2024 | 06:20 AM
Fox-BLUE1's Avatar
Fox-BLUE1
I always had issues with Waze on my 22. I use CarPlay, but the sound always came through way louder than the radio and would scare the heck out of me. I would turn it down and again would default to crazy loud the next time it would voice directions. I vaguely remember having issues with the highlighted route too. I haven’t used it on my 23 yet. Now I just use Apple Maps.
Old Apr 13, 2024 | 07:35 AM
WE3ZS's Avatar
WE3ZS
I only have 540 miles on my ‘24 Lariat Ultimate 450 so far but the Waze app has worked perfectly voice, 12” screen and HUD.
Old Apr 13, 2024 | 08:13 AM
djousma's Avatar
djousma
I had a similar issue, not quite the same, but on your phone, go into system settings>apps>android auto>permissions and remove location access and give that a try.
Old Apr 13, 2024 | 08:22 AM
5picker's Avatar
5picker
Not sure I understand what you are saying?
Are you saying you put in a navigation route, (from within Waze) switch to Android Auto and expect that same route/navigation to transfer to Android Auto?
In my experience, you can switch to whatever screen you want (other than Waze) and the Waze app still runs in the background. (hence, giving you the voice prompts)
I've never seen the ability to have navigation routes transfer from one app to another.
You'd have to cancel the Waze navigation and re-navigate in Android Auto.
Old Apr 13, 2024 | 06:29 PM
BDWSD22's Avatar
BDWSD22
I have a '22 Lariat with SYNC4 and if I'm Navigating in Waze on my phone then go hop in my truck, the WAZE app on my phone transfers to the truck. It used to be buggy when I received my first Power Up. Then it straightened out for the most part in the last couple of months. Try uninstalling WAZE from your Android phone, shut down the truck and open and close the drivers door. Then reinstall WAZE on your phone and then power up the truck. I had to do that a couple of times on the last year after updates crashed my app. Direct connecting with a USB-C cable works better than Bluetooth. Good luck!
Old Apr 13, 2024 | 09:06 PM
Edd505's Avatar
Edd505
exactly! I get the map and warning (various icons) but not routing.
Old Apr 13, 2024 | 09:28 PM
Edd505's Avatar
Edd505
I have uninstalled and reinstalled. I killed my truck in the Android Auto and reinstalled with a USB hoping the last wireless was the issue.
Old Apr 14, 2024 | 08:20 AM
5picker's Avatar
5picker
Again, that's because Waze is still doing the navigation (and reporting in the background) because you've switched to another screen.
The navigation/routing doesn't auto-magically switch to another app.
Old Apr 14, 2024 | 10:14 PM
UKDude's Avatar
UKDude
I've had this problem and there is a workaround.. I think there's a library Wayze needs but doesnt load.. if you start google maps, then switch to wayze, the route will stick 9 out of 10 times..
I'm betting you'll also hear a slight echo from the speech system that sounds like its saying things twice with a tiny offset.
Old Apr 15, 2024 | 04:11 AM
Member No. 1's Avatar
Member No. 1
Rather Be Rid'n!
Not pertaining to Android Auto as I'm an Apple user, so I don't know the workings of an Android phone, but in Apple's CarPlay, what's is happening is the radio is only "Projecting" the phone's screen. The apps are loaded on the phone, not on the radio. So if there is an issue between apps, I would look at any phone conflicts first. I use Carplay on my 2020 Road Glide Limited, and as one of our HOG Chapter's Road Captains, when I lead a ride, I have several Nag apps open. I have found it makes a big difference in the order I open them. If in the wrong order, one will cancel the other since they are competing for the iPhones NAV info.
Waze is a great app, Google maps is very limited for route planning. H-D has their own route planning/Nav app, which sucks, so I use My Route App App Link (have a life time subscription to route planner and Nav) which is very powerful and very easy to use.
Not saying Android is doing this, but it's something you might want to look into.
Old Apr 22, 2025 | 12:19 PM
allpar23's Avatar
allpar23
1st Gear
Hello, I have the same the Same truck with the exact same problem. Did you ever find a solution? I did have a workaround by opening google maps, adding a route (ie. home) then going back to waze and that worked. Now that trick is no longer working.
Old Apr 25, 2025 | 07:39 PM
Squanto's Avatar
Squanto
Maybe I'm not understanding the problem here. I have a 22 with sync4.
If I'm on my couch and decide to go somewhere, I open Waze on my phone and set a destination. If I want to stop along the way, I set that too. Odd you have to put stops in in that order but ok.
Then I go to my truck and Waze comes up on my AA and asks if I'm still going to wherever. I tap resume and off we go.
MBman
6.7L Power Stroke Diesel
15
Jul 2, 2023 12:46 PM
wingedone
Aug 18, 2022 12:29 PM
grizzly660
May 21, 2021 01:49 PM
theklutz13
Aug 13, 2001 12:18 AM
