Calibrating BLIS Blind Spot Sensor
Old Apr 11, 2024 | 07:22 PM
hollyb's Avatar
hollyb
2nd Gear
How do you calibrate or program the BLIS blindspot radar/sensors? My tail lights were stripped from the back of my truck in a parking garage, and along with them, the blind spot radars. The quote from the dealership was outrageous and, having worked for a mechanic shop previously, I am confident this is something I can either do myself or find someone to do. I found aftermarket tail light assemblies (sans radar) that look identical to the OEM lamps for a fraction of the cost. I also found radars from salvage yards, like LKQ and the like, in my area, for much much cheaper than dealer prices.
So my question is... If I get radars from lights at a pick and pull or other salvage yard, how can I program or calibrate those for my truck? What kind of equipment or software is required? Have any of you done this before?
Thank you!
Old Apr 11, 2024 | 08:01 PM
JKBrad's Avatar
JKBrad
Welcome to FTE hollyb,
They should be plug and play. Aftermarket LED tail lights from a company like Mishimoto are far less expensive, just as good, and less likely to get stolen.
On a side note, I peeled the BLIS decals off of mine to help deter any thefts That decal makes the LED lights easy to identify for thieves.
https://www.headlightrevolution.com/...ils?quantity=1
Old Apr 11, 2024 | 10:10 PM
hollyb's Avatar
hollyb
2nd Gear
Thank you so much for that link! You are a life saver!
do you possibly have a link for the radars too? I’ll still need to replace them both, since they were in the stolen lights. 😣 These that you linked me to have the brackets for the radars, but specify that they will need to be swapped from the original lights, as they are not included.
Thank you again!
Old Apr 12, 2024 | 12:18 AM
JKBrad's Avatar
JKBrad
Here’s an eBay listing for refurbished ones. Don’t know if it will fit your truck year or not.
Hopefully the thief was kind enough to unplug them, rather than cut the harness.
https://www.ebay.com/itm/12580677903...mis&media=COPY
Squanto
Dec 8, 2022 04:29 PM
wallace1961
2004 - 2008 F150
Aug 8, 2012 12:26 PM
CentralCoaster
2004 - 2008 F150
Sep 13, 2005 09:54 PM
mtoombs
1997 - 2003 F150
Jun 25, 2002 01:47 PM
tda424
1997 - 2003 F150
May 11, 2002 10:56 AM
