lou'splace
Old Apr 11, 2024 | 09:28 AM
lou'splace's Avatar
lou'splace
3rd Gear
lou'splace
1999 ford f 250 7.3 diesel power stroke has 135000 miles runs great nothing wrong with it until now. truck does not start,. glow plug lite does not come on i changed the relay, solenoid, heater under fuel filter. i put power to the fuel pump it works fine. the fuse is good.
there still no glow plug lite and don't start. what is left to do?
Last edited by lou'splace; Apr 11, 2024 at 09:34 AM. Reason: forgot about the fuse
Old Apr 11, 2024 | 09:36 AM
Tpayne621's Avatar
Tpayne621
Did you check the fuse inside the interior fuse panel? Fuse #30 30a I believe it is. When fuel bowl heaters go bad they will pop this fuse and cause that.
Old Apr 11, 2024 | 09:46 AM
FordTruckNoob's Avatar
FordTruckNoob
Is the WTS light coming on? Go through the steps in the No Start flow chart in the Tech Folder
Ford Version:
https://www.ford-trucks.com/forums/a...4&d=1588427681
FTE Version:
https://www.ford-trucks.com/forums/a...6&d=1564895572
barry66
Mar 20, 2023 09:20 AM
James29760
Sep 8, 2021 01:01 PM
colokerrie
Oct 9, 2012 04:49 PM
FroggF350
18
Feb 5, 2008 12:11 AM
injun46
Dec 3, 2005 11:43 AM
