Happy Tuesday!
Old Apr 9, 2024 | 11:42 AM
BillMc615's Avatar
BillMc615
3rd Gear
Happy Tuesday!
I have a 2019 F350 SD 6.7 diesel, 4 WD. I have noticed a couple times it will shift HARD while driving from 6-5th gear. It feels like I was rear ended! After a few seconds it’ll shift back to 6th gear. I just bought the truck a few months ago. ANY help/suggestions appreciated!
Old Apr 9, 2024 | 12:14 PM
redford's Avatar
redford
FTE Leadership Emeritus
Welcome to FTE.
Are you driving at a steady speed, accelerating, or decelerating when this downshift to 5th happened? Was the downshift expected?
Old Apr 9, 2024 | 01:08 PM
BillMc615's Avatar
BillMc615
3rd Gear
Driving steady, no acceleration or deceleration, flat road. No hills, just cruising along and not expecting a shift at all. My wife thought we hit something. It hit that hard! Fluid looks good, no burnt look or smell. Level is good.
Old Apr 9, 2024 | 01:36 PM
WXboy's Avatar
WXboy
Any idea if the trans maintenance has ever been done? If the truck is over 60k miles I'd recommend changing the filter with a new Motorcraft filter. Put the Dorman OE pan ($30) that has the drain plug back on in place of the one that doesn't have a drain plug if you need to. Then you can drain and fill the Mercon LV as needed. Takes about 9 quarts of LV to fill back to spec once you change the filter.
Old Apr 9, 2024 | 01:50 PM
BillMc615's Avatar
BillMc615
3rd Gear
No idea what was done. Records are nonexistent. I bought it at 94000 miles.
Old Apr 9, 2024 | 05:17 PM
WXboy's Avatar
WXboy
Yeah I bought mine at 81k. First thing I did was go front to back and do ALL the service. Diffs, t-case, trans, engine oil/filter, fuel filters, the whole nine yards. That way I KNOW what's been done and I can take good care of the truck from here. Did it all myself in the driveway and I've probably got $400 total spent on the entire service front to rear. Only thing left is coolant flush which I will do in October when I install the block heater. Good luck.
Old Apr 10, 2024 | 09:25 AM
Mike Bartlett's Avatar
Mike Bartlett
I have the same truck you have. I bought it used as well, had 32k miles when purchased now has 77k. Fortunately mine is shifting fine no issues that you speak of. If no one chimes in with a better solution I would do the a transmission fluid change, as others have suggested. Also a good time to inspect inside the trans also the fluid. I would look closely at the shift solenoids perhaps one is sticking you may see some unusual wear or burnt on fluid?
good luck,
Mike
collinsmc560
Aug 24, 2023 06:08 AM
mzuern
Jun 6, 2022 12:32 PM
Rus01
16
Apr 5, 2013 12:52 PM
RadioFlyer84
Jun 26, 2011 08:33 AM
johnnyt1985
Oct 9, 2008 10:40 PM
