problems with the 347
With the 347, look for the pistons that use a 5.315" rod. These have taller compression heights and keep the pin out of the oil land.
Look at this example:
The sets for the 5.4" rod require an oil rail spacer - the sets for the 5.315 do not. Also not the compression heights of the two.
Probe Pistons
And no, I haven't changed my mind about building the 418.
the problem with most strokers is that the lands between the ring grooves are closer, making the piston weaker for forced induction applications...making the 331 a better choice for forced induction.
earlier stroker designs did not incorporate the oil ring reinforcement allowing the oil ring to flex excessively scratching the bores and creatings oil control/consumption problems. My pistons/rings came with it so no worries there.
If torque is what you want....in a small block package, 3.4 inch stroke is what you want. There are the slightly shorter rod kits that will eliminate the intersection problem.....for those who are paranoid....
so far, I have not seen any scoring of the bores....
Among my theories of the lack of the hyped problems....
good quality components...
Ross pistons, total seal piston rings, Eagle rods and Crank, tight tolerance machining and lightening of crank with balancing being a must.
bottom line is if you want to do it right, don't cut corners.
I did it right and the engine pumps out over 440hp and just about 400 ft lbs of torque on the water brake dyno, revs freely and instantly...no oil consumption has been noticed.
The 331 is a more ideal build up for people with a std block....I got the high dollar SVO R302 block...which can be bored to .120 inch oversized so wear and tear doesn't worry me.
I think the stroker hype is the result of people going out and buying the cheapest kit they can lay their eyes on.....it is a hard lesson to learn
"you get what you pay for" comes to mind.
Stay clear from Probe and CHP kits....once they have your money, you are immediately a burden should any issues come up. They don't stand behind their product.
The success of any project depends on research and development.
I agree that you get what you pay for. However, I wouldn't tell anybody to stay away from Pobe piston's. It is best to arm yourself with knowledge from doing all the research you can before making a purchase. Knowing exactly what you want and need will eliminate future problems. I found that piecing together a combo is the best way to insure you get what you want instead of a compromised kit. The only thing 'good' about a kit is they are quick and easy to order...again you get what you pay for, convenience.
re:I agree that you get what you pay for. However, I wouldn't tell anybody to stay away from Pobe piston's. It is best to arm yourself with knowledge from doing all the research you can before making a purchase.
I made the mistake of going this route....and speak from experience.
I would stay away from these two....and by saying it, I am merely sharing my experience. If you want to give someone your money
and waste your time, go for it.
I also don't like to spend lots of time under the hood, which is why good quality components are the way to go.
Just because you pay for convenience doesn't mean you're gonna get it.
My point exactly.
I wouldn't order a kit from them either (or anyone else), but I would buy their pistons if it fit my application.
